Question about Thermador SMW272 Electric Double Oven
Won't heat When I try to bake something, the oven starts to heat, then stops. Also, the display board's numbers can almost barely be seen and there's a party at our house today, and we have to use the oven today.
  • 1 more comment
  • mazsue Dec 19, 2007
    first the covent. bake would not heat then the bake, now the boil will not heat. display is fine tem just stays at 100.
  • Anonymous Jun 21, 2008
    I have an electric stove when turning oven to preheat, but won't heat up
  • Chasler Feb 01, 2009
    oven element wont heat up. Discovered a work-around by heating oven first with the broiler element, and then amazingly the oven element would work. Now neither the oven nor broiler will work. I too can hear a relay clicking but no heat.
As for the display problem, you'll have to replace the Oven relay board and the display head.
As to the won't heat problem, mine is doing the same thing. On mine the Air Switch has malfunctioned. I hear a steady claking sound as the Stalled Fan relay cycles on and off. When it is operating normally, it will send a steady 120V power to the stalled fan relay. When it malunctions, the 120V signal is eratic and will totally shut off after the oven reaches the mid to upper 200 degree area. Once the oven cools off, you can restart it but the same problem will reoccur.
Replace the Air Switch and maybe the Stalled Fan Relay since it has been getting over used due to the constant on and off cycles it has been going through.
Hope this helps
Posted on May 02, 2008
  • 213 Answers
Theres a oven control/ dislay kit that needs to be replaced to fix both of thoughs problems at the same time
Posted on Nov 25, 2007
Amana Convection Oven - Not heating in normal bake mode, but works otherwise
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
Jan 13, 2014 | Amana Ovens
Broil and range work but bake does not
check oven burner tubes and ignitor and flame sensor
Sep 19, 2017 | Frigidaire Ovens
Baking & broiling elements won't heat after baking element burned out and was replaced.
the surge from the original element burning out has destroyed the control board if you can't hear the relays on the board clicking when you power up the elements bake or broil then its either the low voltage side of the board,if you hear clicking then the relays are working but the contacts are burned out and can't pass the current to heat the oven or briol elements
Jan 04, 2013 | Jenn-Air Ovens
Bake element does not work during convection cooking
Hello and welcome to Fixya.
I hadn't seen your post prior to today, so perhaps you've had a remedy presented to you already.
If you have not, reply to this post and I can recommend a few test to perform that will determine the issue with your oven.
Off the top it sounds like a possible faulty convection heating element or the K3 relay on the board is defective.
I'll watch for your reply.
macmarkus :)
Jun 07, 2010 | Thermador SC302T Electric Double Oven
Oven won't heat, display out, gas burners on stove
Hello, you will probably need to pull it out and put it on something. Make sure the breaker is off to it before you test it. There is a thermostat in the very back that could be bad,check for continuity on that. Also check for continuity on the bake and broil element terminals itself,even though you have checked it to ground. If those check good,then the problems is in the control board.
May 31, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
GE J BP27G R1AD Oven Not Heating Fully
Hi Jeff. You should have a wiring diagram with the range. Check for an envelope on the back of the range, inside the back splash, or taped to the inside side wall of the range if you remove the lower drawer. That all being said, first check to see if the start or stop time knobs on the timer have been pushed in (and possibly turned). If the clock runs, it will clear this out within 12 hours, but on these old ranges often times the clock no longer runs. Make sure these knobs are turned until they have "popped" out or you won't get the necessary voltage where you need it. Secondly, when a bake element burns out, it can cause damage to the electrical contacts in the oven selector switch (part number WB22X5122 ) which can be tested with an ohm meter if you can find the electrical diagram. Also, the oven thermostat (part number WB21X5320 ) can be damaged in the same way. Unfortunately, these parts for these old units are not very cheap.
The little bit of heat you are getting in your oven now is most likely only from the 120 volts going to the broiler element when in Bake. During Bake, your bake element should get 240 volts (until thermostat is satisfied). Setting to Broil should give 240 to the broil element.
Dec 14, 2008 | GE Ovens
Err on display when I try to set the bake temperature
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
or try doing this
1. Turn the clock selector knob to OFF
2. “Tweak” the oven control by turning the clock selector knob slightly to the left (counter clockwise). This may stop the flashing message/beeping and clear the display window.
Nov 12, 2008 | GE Profile JTP18 Electric Single Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Thermador SMW272 Electric Double Oven Logo
286 people viewed this question
Top Thermador Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Thermador Oven Expert? Answer questions, earn points and help others
