Question about Refrigerators
Frezzer leaks into fridge
Water leaks from the spout that comes from the frezzer and drips into the fridge area.
  • 528 Answers
This is usual. In some refrigerators it is designed that way. It will keep the vegetables etc. in the fridge from drying out. Usually this spout is close to the back wall of the fridge. It is designed such that water drips directly to a small hall on the bottom of the fridge. It is important that you don't push the dishes or food in the fridge too far back. Otherwise water will be on you food. This spout should be far back as I mentioned. If, for some reason the water is dripping not close to the back, the spout may have beent damaged or bent. Check to see whether it is OK.
Posted on Jul 31, 2009
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Problem: Water continually drips from water dispenser spout
Should be the water valve in the back. Over time the seals break down our debre in water will cause to leak. Sometimes new water filters will also cause small issues but shouldn't last long.
Aug 18, 2012 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Water seem to puddle up on food trays .in frezzer the floor has quarter inch off ice but the tray under unit is dry even if i unplug unit melt all ice no water drips into tray
The freezer itself does not create water. So the water MUST be coming from somewhere.
First the tests: Turn the water off at the wall, clean all the water from the fridge trays and freezer. Wait 24 hours to see if there is any accumulation.
If not, then you have a leak in your water delivery system to your ICE maker.
consult the manual for troubleshooting. Or return here for further directions.
good luck and don't forget to vote!!!
Sep 28, 2010 | Refrigerators
Refrigerator dripping water from back of refrigerator from frezzer
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 05, 2010 | Kenmore 64802 Top Freezer Refrigerator
I have a side by side fridge/ freezer bought new 5 yrs age and the water/ice dispenser keeps leaking water. I noticed the the lever in the dispenser area seems loose. what would cause this type of problem?
One of two thing. Either the flap is not closing all the way allowing condensation to build up and drip, or you have a seaping water valve allowing water to seep out of the water spout insde the door.
Please rate solution if helpful. Thanks
Aug 19, 2009 | Whirlpool Refrigerators
LEAKING FROM BOTTOM
Is it leaking only when it is filling or all the time? If it is only leaking during fill, it could be an air gap device
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • If it is leaking all the time it could be the main tub seal. Hope this helped.
    Jul 16, 2009 | Roper RAS6233KQ Top Load Washer
    Frezzer coil water is dripping on it
    I'm not sure about your icemaker, but i think it should be fine. Simply put, fridges or freezers have to get hot to make themselves cold, and they do drip water from time to time, although usually not a substantial amount. If you want to learn more wiki fridges freezers etc. the water should be an issue unless there are some exposed electrical wires located near it.
    Jun 09, 2009 | GE GSH22JFR Side by Side Refrigerator
    Jura Impresso E9 not dripping through spouts but into drip tray
    This is most likely due to a bad o'ring. The bar you speak of...Does the unit have a small spout pointing upward from the area?...with a groove? Is the o'ring in that groove damaged or missing? When the grounds are compressed in the piston, the brew unit lowers down onto this spout and seals on it. The high pressure water then is injected upward inot the brew unit. When this seal fails the water simply leaks into the tray when there are grounds providing backpressure. When rinsing and no backpressure some of the water may be getting through. Make sure you lube up any seals with a food grade lube. Olive oil will work in a pinch.
    Mike
    Feb 05, 2009 | Jura Capresso Impressa E9 Espresso Machine...
    Water drips from evaporator fan channel Frigidaire FRT17G4B
    It sounds as if this is a top mounted refrigerator. (freezer on top) If this is the case, check to see if you need to defrost the drain. You could also have a problem with the door seals. Remember the air coming out of the vent is freezer temp minus a few degrees. It could be that the moisture is condensing in that area.
    Feb 01, 2009 | Frigidaire FRT17G4B Top Freezer...
    Dripping shower head
    If it is dripping from the connection where it goes to the water spout you can unscrew the connection and wrap teflon tape or Pipe Joint Compound on the Threads. Now you can Thread the Shower Head Back on, with No Leak. IF..... It is leaking from the Shower Head Itself There May Be a Problem with the diverter handle/lever. If it has a Pull Type Lever, sometimes you can screw the Lever up or down for the proper water restriction to the Shower Head. However if the Hot and Cold Handle/Lever is OFF, There should not be any Water coming out from anywhere! If water is coming out off the Tub Spout, with the Shower Off, then you will have to replace some washers or Cartridges in the faucet(s) to stop the dripping. You can do this easily....Just Ask) Remember though, that some shower Heads may Drip for a Few Minutes After they are Turned off. There is still water in the Supply neck and needs to escape, either though the tub Spout or Shower Head.......Hope this Solution Helps you with your Drips.....Joe
    Jan 25, 2009 | Grohe Aquatower 3000 Shower Tower...
    Water keeps dripping from spout .....................
    usually bc water valve not completely closing . i wud replace it
    Jul 02, 2008 | Whirlpool GD2SHGX Refrigerator
    Refrigerators Logo
    137 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
