Question about Panasonic KX-T7630 Corded Phone
Call forward won't deactivate
One of our handsets is set to call forward. I've tried to cancel by pressing FWD/DND + 0 + # but it won't work. Are you able to let me know how to fix this?
  • Panasonic Master
  • 2,460 Answers
Try *7100
Carl
Posted on Jul 31, 2009
There is a function key "fwd/dnd" is keep flashing on My Panasonic kx-t7030x phone. How should I cancel for it?thanks!!!
The slow flashing indicates that your phone is currently set for Call Forwarding.
To cancel from this phone, pick up the handset (or use speakerphone), then press this key sequence: [FWD/DND], [0], [#].
The light should turn off, and you should hear a confirmation tone. Once you hear the dial tone again, hang up using the handset or speakerphone button.
Source: page 3-19 (79) of http://www.google.com/url?sa=t&rct=j&q=panasonic%20kx-t7030x&source=web&cd=2&ved=0CFoQFjAB&url=http%3A%2F%2Fpdf.textfiles.com%2Fmanuals%2FTELECOM-F-R%2FPanasonic%2520KX-TA624%2520Users%25203.pdf&ei=ycQCUdf0O5To9gTK_YDQAg&usg=AFQjCNEt0-JdZEhH0WCSSp6Sl7VOmARFbA&bvm=bv.41524429,d.eWU
Nov 04, 2012 | Lands Phones
Why can't I turn off the FWD/DND flashing light?
It will flash for 2 reasons. The phone is in Do Not Disturb, The phone is forwarded and the lazy installer didn't change the button indication to solid.
What happens when you press the FWD/DND button on an idle phone? In most systems, it's supposed to toggle between FWD DND and OFF after you press it more than once. If that doesn't work, try pressing FWD STORE 0 STORE. That should turn off FWD/DND and unset it.
However, here's the problem. Your phone may have CF-condition set to send busy and unanswered calls to voice mail. We do that so the individual extension can set his own transfer to VM time. Those commands start with *710x and the VM extension which is 500 by default. For example dialing *7104 500 on the intercom will set CF-NA to the voicemail port on a TDA/TDE system equipped with a Panasonic Voice mail system. When that happens, the FWD/DND light goes either red or blinks red and the forward condition is set.
You can review the operations in the OM for your system under Call Forward and Do Not Disturb.
Carl
Mar 04, 2011 | Panasonic KXDT343 Phone
How to remove FWD/DND FROM A PANASONIC KX-T7030X PHONE
Press intercom button
dial *71
choose the call forwarding type to cancel as follows
dial 0 for internal and external calls
dial 1 for external calls only
dial 2 for internal calls only
dial 0 to cancel call forwarding
press speaker to end
Jan 18, 2011 | Panasonic KX-T7730 Corded Phone
I need to turn of fwd/dnd
Take the handset off the hook, then press the FWD/DND button followed by 0 (zero). When you hear the tone, hang the handset back up. This will work with the PT (Panasonic Proprietary telephone) system. (Alternatively, pick up the handset, press 7 (seven) 1 (one) 0 (zero) 0 (zero) and hang up after the tone. This works for PT and SLT phones (single line telephone))
The same sequence works to cancel call forwarding (except for follow me forwarding). In the Follow me mode, pick up the handset, press FWD/DND or 7 1 0 followed by 8 and the extension number. Then hang up after hearing the tone.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7130 Corded Phone
How do I program the phone to ring on an incoming call? The ringer is on.
The solution will depend on why the phone is not ringing. Do you have a good cable? (Can you get a dial tone and make outgoing phone calls?) If you don't have a dial tone, use another phone to check if the phone is the problem or if the jack is at fault.
Next is the phone forwarding calls or in the "do not disturb" mode.
If the problem is one of the above, which model of the Main Unit do you have, KX-TA624 or KX-TA1232?
If the unit is in the "do not disturb" mode, to cancel: pick up the handset, press Program then 0 followed by # with the TA624. For the other model, press Program followed by 0 . Then hang up the handset. For this the manual says press the FWD/DND button not the Program button. I'd check both.
To cancel Forwarding, except for Follow Me Forwarding, pick up the handset, press FWD/DND and then 0 and # (TA624) or 0 (TA1232) then hang up the handset. To cancel Follow Me Forwarding: pick up the handset, press FWD/DND then 8 followed by the extension number. Then press # for the TA624 and hang up; just hang up the handset for the TA-1232.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7730 Corded Phone
How do I divert calls to a mobile number and then undivert calls
pickup the handset (phone... watever) and press the FWD/DND button then press #2 then type in the number of the mobile (or number you want to forward to...), and hang up the phone... then when your finished with the call forwarding function, press FWD/DND again and this time press #0
What 2 does it turn on the call forwarding feature
. and 0 turns off forwarding/do not disturb functions
theres 5 different functions after you press FWD/DND
0: turns FWD/DND off
1: put the phone into Do Not Disturb Mode
2: call forwarding
3: Busy-Forwarding.. which means if your on the phone and someone rings, it forwards them to the number you specify
4: No Answer- when you don't answer the phone if forwards the caller onto the number you type in
and lastly 5: Busy/No Answer- does both function 3 & 4
i hope i've helped
, Cameron
Jan 22, 2010 | Panasonic KX-T7630 Corded Phone
Call forwarding
Lift the handset, press the FWD/DND button, dial 2 and the extension you want your calls to forward to, you should get a comformation tone, hang up the handset.
Cancel the fordwarding by lifting the handset, press the FWD/DND button, dial 0 , get tone, hang up.
Good Luck
Jul 30, 2008 | Panasonic KX-T7730 Corded Phone
CALL FORWARD
hi prabipm,
just follow this instruction.
1.lift hand set or press sp-phone
2.press fwd/dnd botton
3.press 0 and # sign
hope this help...
Jul 23, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
208 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
