Question about Durabrand DWT1905 TV
T.V. is not changing cannels
Every time I plug in the tv numbers are on the screen the number 2 on all four corners the numbers 069-0.02 271 followed by a black rectangle. On the bottom OB 92DE. All i know is that my girlfriend pushed a button on the universal remote and it hasnt worked right since. You cant change the channel turn it off or anything else just some wierd menu options. How do I get it working again
  • 7 Answers
SOURCE: remote
Check this forum again- an answer is now in one of the other similar threads using a DirectTV remote. :)
Posted on Feb 02, 2008
mediarich
  • 188 Answers
SOURCE: menu settings
Online users manual is offered here.
http://www.usersmanualguide.com/funai/television/dwt2405
Have you unplugged the TV for a few minutes and then plugged it back in? According to the manual that seems to reset everything.
Posted on Sep 27, 2008
SOURCE: Durabrand tv won't work with vcr/dvd player
I was given a dwt1905 tv for my kids without a remote so they would have a tv for there dvd player and games plus cable comes to find out I was not able to control anything I listed above with my cable remote because there is no codes you have to buy the remote from the company I called 3# before I was able to find out anything about a remote the contacted # is 1-800-242-7158 and the cost was 19.99 for a new remote that is the only way you will be able to work the tv with dvd player,game systems and cable I hope this helps........ good luck
Posted on Oct 17, 2008
  • 5 Answers
SOURCE: The GE Universal remote doesn't properly work my tv
Do code 0157 it works
Posted on Mar 09, 2009
SOURCE: Durabrand DCF2003
why can i hear my dvd playing but no pic do i need to a different wire
Posted on Jan 20, 2010
Have numbers and letters on screen and wont go away, im able to see the picture but no sound sound from tv. these are the numbers that appeared on screen 058-0.06 271 A1 (top) 0F F6FD (bottom) and the...
U have the tv original remote wright?This problems likely parts of Close Caption problems.Look for a button that said CC on the remote press it make sure all like CC1,2,3.. to off should solved this problems.Or tries go into the main tv Menu looking for Close Captioning functions turn off to all CC1...and Text1... all to off.Will fixed this problems.
Jun 07, 2011 | Emerson EWF2004 20" TV
Have it on cannel 4 04 but VOX is in the upper left corner. can hear but can't send.
The manual isn't specific, but your VOX feature likely works only with an optional external mic. To turn this feature off for normal use,
- Press MENU four times (display will show VOX)
- Select oF by pressing the up or down arrow key
- Push the PTT button to confirm and return to normal operation
Dec 22, 2009 | Midland LXT310 2-Way Radio
Not reading the disc
need a bit more info - are you playing a movie or running software installation?
If you need to change the drive region then do the following
1. Power on your DVD Player without a disc in the drawer.
- Wait for the "Loading" screen to finish and then the display reads "no disc".
Check which region your reader was bought in. (Large Number label is located on the rear of the Player. Region 1 to 6)
-on the remote control
2. Press the "Repeat"button. The "no disc" label on the screen will disapear.
3. According to the region your player was bought in, choose from the following button sequences.
- region 1, press buttons 2, 9, 3, 3, 4
- region 2, press buttons 5, 7, 5, 3, 8
- region 3, press buttons 5, 6, 7, 3, 2
- region 4, press buttons 7, 6, 8, 8, 4
- region 5, press buttons 5, 3, 8, 1, 4
- region 6, press buttons 2, 4, 4, 6, 2
4. The number in the top left corner of the screen shows you the current region. EG "1" for the US/Canada, "4" for Australia/NZ.....etc.
5. Now enter the new number for the region you require (1 to 6)...or simply enter 9 for "Multi-region". The number in the left hand corner of the screen will change to the number you enetered. Wait for the number to dispear. It will take around 15 seconds.
6. Now power off the DVD player with the button on the front of the unit. Now each time the unit is turned on it will be in the new region...or muti-region if region 9 was chosen.
7. If you wish to change the region again...or back to its original, go through the exact same sequence until step 5. Then you enter the different region number.
If you are unsuccesfull with the above code then it may be worth trying one of the resources below.
Jul 24, 2009 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Cant reset the region on my philips DVD736K player
Please rate my solution if this works:
1. Press the tray "open" button on the DVD player.
2. Enter the following numbers slowly on the remote control "1111" - 'note you will see nothing on the screen'
3. Press "0" on the remote (take note of TV screen to ensure you select the right number. TV should show " New region 0" in top left hand corner of screen.)
4. Press "open/close"
Feb 21, 2009 | Philips DVP5140 DVD Player
Number 2 in upper right hand corner of screen
Had this problem also when I rebooted my Time Warner Cable box. Unplug everything from the wall including power strip and wait 60 seconds then plug back in and turn everything back on. Worked for me and havent had a problem since. Time Warner does not know what causes this yet.
Jan 28, 2009 | Samsung LN46A530 46 in. LCD HDTV
Tv/vcr combo wrong cable channels
This could be one of two problems, either the TV tuner card is set up to accept the wrong type of signals (which normally can be changed in the menu of the television) or the card isn't capable of translating the signal (with most cable companies going over to digital signals with their boxes translating the signals over.) My suggestion is to check to make sure the proper signal type is set in your menu (if in fact this is even an option for this particular television) and if that doesn't work get a generic analog digital cable box.
Sep 12, 2008 | Philips 43PP9202 43" Rear Projection...
Numbers on my tv screen
It sounds like your tv has a programming problem not to do with the remote but the actual tv you will have to take it in to get repaired or you just might have to buy a whole new tv
Mar 20, 2008 | Universal Remote Control Remote Control
Tempermental TV
Hello Sir,
I hope your tv is the power problem or the main board.
But if this the back light problem then you don't need to repair your tv just sale as part (cause this back light part is hard to find and the cost is high).
You need to sent this tv for inspection. any question call me at 323-767-6030
Jan 31, 2008 | Astar LTV-3201 32 in. LCD Television
How to clear all information from screen
screen has (m3)and (m1) in upper left corner, have not been able to totally clear screen.
Apr 10, 2007 | Texas Instruments TI-30XA Calculator
Durabrand DWT1905 TV Logo
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
