Question about Sony Cyber-shot DSC-W80 Digital Camera
When I turn it ON it says TURN THE POWER OFF AND ON AGAIN. The lens is not retracting when I turn it off.
My camera was doing the same thing. I just gave the lens a light twist back and forth and my camera started working again.
Posted on Aug 11, 2009
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Lens won't retract
According to Sony, storing the camera lens-down in a warm area for an extended period (a week) can help re-lubricate the retractor drive in cases like this.
This camera seems to have a predisposition to lens retraction problems. Try some gentle nudging, Even a small piece of debris can jam the mechanism, so it might just need a little push or pull.
Apr 16, 2008 | Sony Cyber-Shot DSC-W5 Digital Camera
Screen says turn the power off and on again and lens stays out
Lens jammed & requires manually resetting.
If you are in the UK I can help you out.
p.m at kiddo242@hotmail.com
Aug 18, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Samsung L100 digital camera beep problem
If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work.
If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
Hope this advice helps!
Aug 04, 2009 | Samsung L100 Digital Camera
Same for me. Does not turn off
This is normal. It is like a soft power-off to conserve battery life. To turn it back on just hit the ON/OFF button again. And then turn it OFF with the same button and the lens should retract as normal. The time out only powers down the electronics, it doesn't power down everything. you have to turn the camera off manually to turn it ALL off, including retracting the lens.
Jul 25, 2009 | Olympus Camedia C-770 Digital Camera
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Jul 28, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Turn the power on and off again
I fixed this issue with my Sony Cybershot by gently (carefully) hitting the camera 3 times against a carpeted bench with the lens retracted and the camera turned off. It seems the lens gears were stuck. Now the camera works fine again.
Apr 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Lens extended can't take pictures
The only thing not functioning was the lens I could turn on off see menus etc but could not take a picture and the lens would not retract - My husband cleaned the battery terminals on battery & in camera -IT WORKED !!!! good as new -
Apr 06, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
Lens will not retract
It sound like a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse. Good luck!
Sep 11, 2007 | Panasonic Lumix DMC-LZ2 Digital Camera
My Sony Cybershot lens is not retracting!!
The lens block needs a replacement and you need a good service center for this job. We can help you in spares supply. Do let me know as this is an expensive spare part. Sonyspares
Jul 31, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Sony Cyber-shot  DSC-W80 Digital Camera Logo
270 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
