Question about Frigidaire FRS26R4A Side by Side Refrigerator
Ice maker won't fill with water
I can hear the ice maker activate, but no water fills the tray. Also the water dispenser on the front of the unit doesn't dispense water. I have checked the line and water flows to the back of the refridgerator. Is there a switch or solenoid or something that needs replaced?
Replace selenoid valve
Posted on Aug 20, 2009
  • 3 Answers
There is a soleniod near where the ice line hooks in, Take it off and clean it with hot water and soap, if that does not fix it it may be bad
Posted on Jul 31, 2009
Ice maker will not fill with water.
You mean " Why The Water Doesn't Fill the Tray in Kenmore Ice Maker?"
Am i right to your question? Well, Kenmore brand refrigerators often have an ice maker that uses the water supply to create ice inside the freezer compartment. Some models have an ice dispenser on the freezer door for easy access, and others simply create ice and deposit it into a tray inside the freezer. While most ice makers should work well with basic maintenance and care, issues may occasionally arise. One such problem is if the water does not fill the tray to create ice inside the ice maker. Resolving this issue may be possible through some troubleshooting efforts.
1 Remove the ice bin from the freezer.
2 Fill a turkey baster with hot water.
3 Spray hot water from the turkey baster into the tube at the back of the ice maker, which may be frozen or clogged.
4 Repeat spraying water into the tube until the blockage or frost is removed.
5 Replace the ice bin into the unit.
Please let me know if this help you.
Thanks for using FixYa
Sep 06, 2011 | Refrigerators
Ice tray not filling with water, water dispenses fine
You Should remove the ice maker and check to see if the plastic water dispenser tube is frozen with ice. if so thaw it with a hair dryer until it's clear. If the problem persists you may have to replace the water fill solenoid in the back of the refrigerator. There is 2, one for the water dispenser and 1 for the ice maker, usually they are connected as 1 unit combined so you would have to order it that way.
This information is based on the Ice maker is advancing properly.
May 11, 2011 | Refrigerators
Ice tray won"t fill with
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Apr 26, 2011 | GALAXY Microsystems 25.4 cu. ft....
I have a kitchenaid 23cd.Icemaker doesn't work has 40# water pressure 5 deg in freezer water works to fill glass no water in ice tray unpluged for 24 hours
If the water dispenser is working and fill glass function is working but the ice maker section there is no water in the tray then its faulty ice maker valve.This is a twin valve.The valve is one unit,but has two sections one for water and one for ice dispenser.This valve is got faulty and not working for both sections so water is not entering the ice maker tray.
There is a water valve at the back of the ice maker.This valve controls the flow of water in the ice maker chamber.If this valve is not functioning as required then water will not enter the ice maker.This valve is at the back of ice maker connected to the water fill tube.It has to be replaced to clear this problem.
Feb 01, 2011 | Refrigerators
Maytag sidebyside MSD2758DRW ice maker won't make ice
If the ice maker no longer make ice, check the following.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on.
On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice.
Check your door seals and thermostat, repair/replace as necessary.
Thanks
Jul 10, 2010 | Maytag Refrigerators
Ice maker no longer works. It has been working for years and all of the sudden the ice tray does not fill up with water, however the water dispenser dispenses water just fine....
The unit uses a dual water and possibly the side which supplies the ice maker has become defective. Also check to see if the fill tube has frozen.
Apr 30, 2010 | Thermador KBUIT4260A Stainless Steel
Ice maker not producing ice. Tried everything in the Troubleshooting section of Users Manual. Replaced water filter. The front water dispenser is working.
the most likely thing would be a bad water valve.try to reset the ice maker and watch to see if the tray fills up the fill tube could also be blocked with frozen water.the last thing is simply a bad ice maker.
Sep 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water leaking through ice maker
check out the temperature inside of the freezer your probebl going to have to clean the condenser coiul underneith the unit
May 23, 2009 | Whirlpool ES5FHAXS Side by Side...
GE Profile Performance Refrigerator - Ice maker problems
About every two hours you should hear the ice maker cycle. The easiest way to check is to turn the ice maker off using the arm up in the off position. After a few hours open the door lower the arm and observe. The plastic fingers should advance ejecting the ice into the tub. A few swconds after the ejection you can hear the valve and should hear the water fill the tray. If no advance with the ice maker than ice maker,warm temperature, or wiring. If no solenoid sound (ice maker ejector rotates)than electrical or solenoid valve. Solenoid valve and no water - frozen fill hose, blocked hose or unlikely but possible faulty solenoid valve. If you can hear the valve it should pass water!!
If the ice maker doesent cycle CK the temp of the freezer! Must be cold enough for ice maker to work. zero or colder will work for sure and 0 or so is the right temp for freezer. Above 20 don't think it will cycle and would be an indication low freon or bad compressor in unit.
Jan 15, 2009 | Refrigerators
Just installed ice maker cords, no water filling ice trays
Hi make sure that the arm on the ice maker is in the down posistion as it will only put water in the ice maker in this posistion. It will take a little time to fill so be patient as the timer in the front on the ice maker needs to cycle first. Make sure you have connected it all correctly to...
Dec 29, 2008 | Whirlpool ED2FHEXN Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
501 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
