Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Won't start, has "varnish" from fuel
3 year old YTH2148 has had problems since 1st year; backfires, sputters unless choke is wide open, dies when the blades are engaged; less than 50 hours on the machine. have cleaned & rebuilt carb at least once per year; twice this year & it is still having problems. have changed all filters & plugs. continues to get nasty fuel residue and won't run. any suggestions?
  • 560 Answers
Does it have a fuel pump or is it gravity fed? If gravity fed, when you rebuilt the carb, did you make sure that the main (power) jet orifice was totally clean? No varnish or residue in the hole. Pressurized air or carb cleaner spray into the jet is a good way to test flow restrictions. It sounds like a clogged main jet or a vacuum leak at the carb to manifold gasket. You might want to flush the gas tank and replace the gas cap also, as evaporating fuel over time will leave behind varnish deposits if the cap doesn't seal, even though it is a vented cap.
Posted on Jul 31, 2009
Why does my ATV bog down and die when I keep the throttle wide open?
If you are lucky, you might just need new fuel filter and the fuel bowl cleaned out, and maybe new air filter. If not so lucky you need carburetor rebuilt. Backfire is usaully caused by engine running too lean ( too much air for the amount of fuel present). Fuel bowls get gunk in them and the fuel needles and fuel jets get varnished up. The accelerator pump gets worn out gaskets and/or bellows and doesn't give the right amount of fuel mist when you accelerate.
Full Choke is indicative of a motor starved for fuel
Mar 04, 2015 | ATVs
Why does my yamaha 660 only run if the choke is on? What causes it to backfire?
Most of the time it's because the Pilot/Idle jet is clogged in the carburetor. This most often happens because of old fuel sitting in the carburetor during long periods of sitting and non-use. The fuel forms a varnish - a gummy layer inside of your carburetor and clogs the tiny holes in the idle jet. Since fuel can't get through, the engine dies. The hole for the choke is larger, therefore the fuel can still get through it.
clogged carb jets Google Search
Jul 20, 2014 | Yamaha 2005 Grizzly 660 Auto 4x4
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
2001 Shadow Sabre, Won't idle with choke off unless giving it some throttle.
Hi, Rickgilbreat and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Starts but won stay running unless with choke Discussion
Won idle without choke
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Aug 23, 2012 | 2001 Honda VT 1100 C2 Shadow Sabre
1989 oldsmobile cutlass ciera car starts but won't stay running it sputters and backfires and dies
sounds like a timing chain or timing belt if i had to guess,but unless you are a car buff something that old is not worth repairing.
Nov 21, 2011 | 1989 Oldsmobile Cutlass Ciera
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
2002 Honda VT 1100 C2 Shadow Sabre will not idle without the choke being on
Hi, Esw2035 and the usual suspects are:
Need Help Bike won run choke in
Apr 21, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
Runs for 5 seconds with choke pulled;no crank without choke
check your fuel pump to see if working,, then clean or replace carb,, and do tune up on it,,, hope this help you,, good luck
Aug 12, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Have to choke MTD to keep it running
check fuel pump diaphram is not streched or hard, check fuel filter for blockage, or fuel tank cap might be not venting, if none work drain and clean out carby bowl.
Jul 19, 2009 | Mtd LAWN MOWER PART # 787-01341...
2002 Dyna wide glide. Will not IDLE
not running for a year! You have a varnish buildup in the low end circuit of the carb. You will need to remove the carb and do a full teardown of the carb to properly rectify this problem. SOMETIMES we are able to free up the passages by putting SEA FOAM cleaner in the tank , fill her up with fresh fuel and ride through the tank and it will clear up. SEA FOAM can be purchased at an auto parts store and is sometimes very effective. 1/4 cup to full tank fuel.
Jul 13, 2009 | 2002 Harley Davidson FXDWG Dyna Wide Glide
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
354 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
