Question about Samsung SyncMaster 753S 17" CRT Monitor
Monitor turns pink
Recently my monitor's has turned to pink.
can u help me
please solve this
as soon as possible
    Scholar:
  • 35 Answers
First I would check the end of the cable that plugs into the computer, if this has become loose, it can cause discoloration. If it isn't loose, unplug the cable and see if any of the pins have become bent on the inside. IF they have become bent, you can usually carefully use a pair of tweezers to slowly bend them straight again (be careful because if you aren't you could break the pin off). If your monitor has the ability to removed the VGA cable from the monitor, you might try replacing the cable (most CRT monitors do not support removing the VGA cable though). Lastly, as this is a CRT monitor, you might need to Degaus the monitor or the electron gun could be coming out of alignment. Most CRT Monitor's have degaus button (usually marked by a symbol of what kind of resembles a horseshoe) which if pressed will degaus the monitor. If your's doesn't have a degaus button, try searching through your menu for the degaus option by hitting the monitors menu button. To see if your electron gun is out of alignment, lightly tap the side of the monitor. If you see the color change, or the color returns to normal, your electron gun is out of alignment and will get worse over time. Buying a new monitor is usually the best option if this is the case.
Posted on Jul 31, 2009
I have view sonic VA1912WB 19'' black lcd monitor.. recently im acing problem with it..after i turn on the system the green light blinks and there is no display on screen.. after several(5-6)...
try another monitor on your system if you can barrow one somewhere to eliminate that it may be the computer... if it is the screen check the warranty on it at the view sonic web site... also check the cable from the comp to the screen to see if it is lose. try another cable or if it has hdmi dsub or dvi try those types as well. it may have a lose connector on the one your using...
May 20, 2011 | ViewSonic VA1912wb 19" LCD Monitor
I can't get the monitor and the camera to sync.
Turn on your monitor and camera. Click the menu button and choose, add camera. As soon as you do, push the "code" button in on the back of the camera. You should see a picture soon after.
Aug 23, 2010 | Summer Infant Slim Secure Handheld Video...
Vertical lines in my HP screen
Please check if you get those line as soon as you turn it on, If yes, so need to get a replacement for the screen , and if it is no, try updating video driver of your system from the manufacturer website.
Hope this work
Cheers!!!!
May 25, 2009 | HP f2105 Monitor
My LCD monitor turned Pink
The reason its pink is that the backlight bulb is on its last legs. They turn pink or reddish before they go out completely. Eventually the backlight will need to be replaced.
Please rate this fixya
thanks
May 04, 2009 | Computers & Internet
Pink viewfinder screen and pink photos
I am afraid your CCD is faulty.
No diy possible unless you can find a working CCD-chip.
Dec 20, 2008 | Fuji FinePix S5000 Digital Camera
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
System recovery
First, turn off your PC, then turn it back on and insert the Recovery Disk right away and turn the PC back off as soon as you put the recovery disk inside. Turn your computer back on and it should give you the recovery options.
PLEASE RATE MY ANSWER AS SOON AS POSSIBLE!
Jun 17, 2008 | HP Pavilion F50 17" Flat Panel LCD Monitor
Monitor screen turned into pink
A defective monitor cable can cause the monitor to turn pink.
May 13, 2007 | SAMTRON 55V 15" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
455 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
