Without knowing the model for the unit, it makes it a little difficult to troubleshoot, but usually the easiest way to get one of these to open up is to try resetting them. This is done on MOST DVD players by unplugging them for about 30 seconds while you hold the power button down to discharge any power that might be held in the unit, then plugging the unit back in and trying to eject it again. Keep in mind, that if the unit was moved (or even if something caused the unit to shift, like a person jumping near it) then the problem could be the dvd has become dislodged from the tray. Many dvd players will have a small hole on the front (usually below the tray) where if you insert a paper clip in about a half inch, will eject the tray part way, and then you can gently pull it out the rest of the way (making sure you do not keep pulling if you feel resistence as the dvd might have skipped out of the tray track). IF worse comes to worse and you don't have a warrenty on the unit, many dvd players can be opened by removing 1-2 screws from the left and right sides, and possibly 1-4 screws from the back of the unit (look around the edges, the screws near the ports on the back usually holds those ports in place and do not need to be removed to take the case off). Once the screws are removed you would pull back and up on the case to open the dvd player. Keep in mind, this voids a MFG warranty. Once the case is off you should be able to see the dvd and remove it unless you have a cheap dvd player which has an enclosed drive. Remove the dvd and with the case still off, plug the power in (DO NOT TOUCH ANYTHING INSIDE WHILE THE POWER IS PLUGGED IN) and try hitting the eject button on the front. IF it ejects now, you should be good to go, just put the case back on. IF it doesn't eject, then your motor is probably bad (or something is blocking the track) and it is usually safer/easier at this point to just go buy a new dvd drive.
I would like to set channels other than the 1-6 for recording programmes. Presentley the dvd...
(More)
I would like to set channels other than the 1-6 for recording programmes. Presentley the dvd recorder only gives the option of recording channels 1-6 but we would like to record other channels while we are out.
I have a Toshiba dvd/vcr player model DVR3SU that gets an "error reading disc" message...
(More)
I have a Toshiba dvd/vcr player model DVR3SU that gets an "error reading disc" message frequently, I would like to locate and adjust the potentiometer if that can be done. I have no electronics experience, but I have been able to take the unit apart to the point that most of the disc area is accessible. thanx
I have purchased every type of disk that they make to see why my Toshiba VCR DVD Combo gives an...
(More)
I have purchased every type of disk that they make to see why my Toshiba VCR DVD Combo gives an error message everytime that I push dubbing to record to the DVD. I get an error message everytime I try to push record
My problem is this: recently, Comcast has been converting all its customers to a digital signal and...
(More)
My problem is this: recently, Comcast has been converting all its customers to a digital signal and installing these DTAs (Digital Transport Adapters) on all its customers' older TV (including mine). But the issue I have is with recording programing on my non-digital Panasonic DVD recorder. Since I installed the DTA, I've discovered that the only way I can record a program on a specific cable channel is to move that channel to Channel 3 or 4, before I leave my home. This means this is the only channel I can record (during my time away) is on that one channel.
How can I record multiple shows on different cable channels using my DVD recorder? Comcast says I need a spliter, but will this device allow me to program my DVD to record multiple shows on different cable channels? I'm confused. Thanks for any help you can provide.
