Question about Standard (CRT) Televisions
TV not working properly after changing locations
I just bought a simple 13" TruTech TV yesterday. I have cable tv through Suddenlink. I plugged in the cable and the power and went through the initial set-up "autoscan CATV" yesterday, and everything worked. When I turned it on this morning, I had to run through the autoscan again, but then it worked. So, I moved it to its permanent location, and of course had to unplug/replug. Now I can only get the upper channels, and the quality of the reception disintergrates as it gets to the lower channels, e.g. ch.19 is very poor quality and ch.3 is completely white screen and noisy. I have unplugged the connections several times and run the autoscan multiple times. Any idea what's going on? Thank you for any help you can provide.
  • 68 Answers
SOURCE: f32650/atc113ca1
This could cause a problem, because modern TVs and most other entertainment electronic goods, have a small kind of computer chip, but there should be a Reset button probably inside the set! If you feel confident about computer chips you may be able to find the button by tracing the circuit.(Disconnected from the mains). Another idea is if there is a small button cell or battery inside, then try disconnecting it for a day. Good Luck!
Posted on Dec 02, 2006
  • 275 Answers
SOURCE: Tv problem
Did you check your Signal input source? The Cable Box ot the antenna or the antenna cable? Check the Cables from your DVD player or your VCR aklso. These are the Input Sources, and if your TV is not detecting them, them for some reason there is no signal being fed into the Tv.
Posted on May 12, 2007
  • 1153 Answers
SOURCE: Can't get cable channels, only goes up to ch. 13
First check and see if you are on Cable or Ant. It sounds like you are on ant. Change it to cable. If you are on cable then it's you tuner, you need to replace it.
Posted on Sep 14, 2007
SOURCE: Tv problem
Mine (2005 vintage) is doing the same thing. Wiggling the connector at the rear of the set cures the issue. however, it must be a loose connection inside. How about soldering the connector?
Any other ideas on how best to handle the soldering of the connector inside the set?
Posted on Oct 13, 2007
SOURCE: How to unlock my Konka K2001UM TV
I cannot find the manual, it should be lost. Any more suggestions?
Posted on Jan 17, 2008
SOURCE: Sony FD Trinitron WEGA KV-24FS100 24" TV On/Off problems
I have spent about 4 hours tonight researching several tech sites and the Sony service manual for the same problem with my Sony KV-32HS510 unit. I was able to download the manual from a website and a TV Repair training lecture paper at .
These TV sets have a safety feature where it will shut back down if a high voltage is indicated. Unfortunately, the electronics for these safety features are not very reliable and give false indication. Letting the unit sit off lets the capacitors leak voltage as well as cool off. These two factor help with the unit not falsely indicating a high voltage condition.
The D Board seems to be the most common failure component, but a 6 times flash could be an overcurrent/voltage failure from the A, B, or M boards. A 7 times flash is a Horizontal Deflection Stopped error with no additional information given in the manual for a fix. Again, in most blogs, the D Board seemed to the source of the failures.
A refurbished D Board part no. A1300319A can be bought for around $200 with a new board at $550 per the site. Then add $100-$200 for an actual TV service technician and you have a repair bill approaching the costs for a new flatscreen TV.
Some tech types posted that they have actually repaired their boards by replacing individual components for around $40. You may find a service shop that can do the same component level repair at the $100-$150 level cost. It turns out that the closest authorized Sony repair shop is 2-1/2 hours away from us. Good luck finding someone close by.
We were able to get our TV to come back on after dozens of attempts and plan to leave it on until it dies all together. I may attempt my own D Board replacement when the time comes.
Posted on Jan 07, 2009
0 characters
1 Points
"Model KV-36FS210" "Sony TV" Suddenlink service issue
Hi - My name is Ashley, and I'm with Suddenlink. I'm sorry to hear that you're experiencing issues with your cable TV service. If there's anything I can do to help, please feel free to contact me directly at ashley-AT-suddenlink-DOT-com. Thank you.
Apr 26, 2014 | Standard (CRT) Televisions
My tv don`t have sound,yesterday i change the ci TDA7056, BUT ONLY HAVE SOUND ONE HOUR THEN NO SOUND NO MORE
TDA 7056 Audio IC
3 W mono BTL audio output
Many things to consider:
Supply voltage on pin 2 , nominal 11V
Speaker should have 16 ohms impedance
Insure that it is mounted properly on the heatsink
check the solder joints
check for additional components around it.
Aug 27, 2012 | Samsung TXH1370 13" TV
Why can't I get reception on my TruTech tv model DW19TT even after plugging in a Phillips digital indoor tv antenna
If the antenna is working and you are not receiving a signal, then you could have a bad tuner, use a tuner from a VCR , connect the ant to the VCR and go from the VCR with Video cables and go to the Video input on the TV and put your TV in Video mode. That will work.
Nov 26, 2011 | Standard (CRT) Televisions
Help. I got a used TruTech t200d for my nine year old. we were able to hook up and play on playstation 2, but are unable to get the tv to pick up the comcast channels. we do not have the trutech remote...
U able to go into the tv Menu?Yes,goto SETUP changes Pick CABLE and scan for channels for the Comcast CABLE channels.Or Try website like to buy an original tv remote.
Mar 04, 2011 | TruTech T2000D TV
Unable to get tv on proper input to show att uverse. tried channels 3 and 4 and on av 1 and av 2 still no pic
hi, try to check the on the cables if they are properly plugged, try to check as well if you can access video mode. hope this helps goodluck!
Jun 11, 2010 | TruTech T2000FT TV
Do they make a 27 in in this tv
Universal remotes are so cheap now I would just get another one and program it for your TV. You can also get original remotes at Let me know if you need anymore help.
Thanks for using FixYa
Mar 02, 2010 | Funai Trutech 13" TV
No remote for T2000D 20 inch TV. Bought a Trutech
I have a Logitech Harmony 550 that does the job very well.
Nov 15, 2009 | TruTech T2000D TV
How to hook up cable and get more channels than 2-13????
Change setting in menu to cable from tv or antenna. May be in channel setup menu.
May 12, 2008 | Standard (CRT) Televisions
Lisa, your set is switched to antenna mode, (roof top type antenna) you need to find the switch usually located inside a little door on the front of the tv and switch it to "cable" position.
If the tv is not that old than it will be located in the tv`s menu listing which is electronically set not a slide or push button, either way that`s your problem , good luck finding the switch it`s there somewhere.
Nov 27, 2007 | Standard (CRT) Televisions
Standard (CRT) Televisions Logo
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
