Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
My GE Profile doesn"t drain completly, leaving about 2" of water.
Washes and rinses but leaves 2" of water on bottom. Its 15 years old. Works well until now.
  • 49 Answers
Sounds like a water level sensor is on the fritz. The drain valve is probably opening if the level drops at all.
Posted on Aug 06, 2009
Ge dishwasher not cleaning dishes and leaving debris behind
check for corrosion or debris in the water jets clean if necessary
Mar 11, 2012 | Dishwashers
Washer does not drain, and leaves water in the
hi..The drain is clogged.check the strainer at the
bottom of your unit.Always rinse your dishes of food
before putting them in the washer.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | GE 24 in. Profile PDW7800 Built-in...
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
GE NAUTILUS GSD3200-J00WN DISHWASHER WON'T COMPLETELY DRAIN
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Dec 27, 2008 | GE Profile PDW9880NSS Stainless Steel...
GE Profile Dishwasher (5 years old); Leaving residue on dishes
In my case the counter mounted breather for the drain tube was being restricted ... finally to the point it would not drain the tub at all. I disassembled the above counter drain assembly and cleaned it out as it wass completely blocked and things work very well again. I would suggest this foirst as it is an easy task and is done 'above the counter'.
I then ran 2 cups of CLR with wash cycle ... no dishes to clean out the rest of the washer as on dissaembly of the internals to diagnose they were and very scummed up with a hard white crusty substance that was completely blocking some of the drain sump performations.
Dec 09, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
402 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
