Gateway mx6446 laptop red flashing light
My gateway mx6446 laptop has a red flashing power light. I bought a new battery it worked for 5 - 10 minutes and said it was low on power, I had it plugged in but it was not charging. I bought a new charger / power cord and still it will not boot up. Is there something on the mother board that is bad or is there something else I can do to check what is wrong. I don't understand what the problem could be. Thank you.
  • swood8888 Aug 02, 2009
    Thanks, I suspected it might be the motherboard I have seen this on another dell laptop before. The system is out of warranty. It just might be time for a new netbook but I hate to scrap this one.
  • 453 Answers
The problem is with the main board in the power supply section.
This is because the powersupply must have been short and the battery is not getting charged because the power supply isnt charging the battery.
Kindly contact the manufacturer for a main board related issue and there is no way we can lay our hands on the main board the best thing would be to go for a replacement.
Posted on Aug 02, 2009
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
Gateway laptop model W350i will not boot. When power button is pressed, red light flashes four times. Replaced AC power adapter, tried removing battery and power with AC only, still does the same thing. ...
It's a hardware failure like a cpu fan not working or faulty ram.Check the gateway site for an explanation of the lights. It's flashing a trouble code.
Jul 12, 2009 | Computers & Internet
I have a Gateway NX560XL laptop. The other day it was on battery power and it said it only had 5 minutes left. So i plugged it in, but the charge icon did not show up and it didn't start charging. After...
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Jul 01, 2009 | Gateway MT6840 Notebook
Cant get it to turn on or charge
Flashing red light 3 times and won't boot. I recently recalibrated the battery and again the 3 flashing red lights. Seem to be draining the battery fast. It's also a new battery...which work for about 2 weeks before the 3 flashing red lights first started. Now 2 batteries later. It won't boot.
Apr 26, 2009 | Gateway MT6840 Notebook
I have a gateway ma7 laptop and press power and get nothing
When the computer is off, unplug the power cord from the laptop and then plug it back in. See if the charge light (lightning bolt symbol next to the led) comes on or turns green/blue. If it doesn't your power supply may not be working, even if the light on the supply is on. Second is the battery may be damaged. Remove the battery and see if you can power on at all.
If it boots with only the cord, the battery is bad/shorted forcing shutdown.
Apr 11, 2009 | Gateway MT3705 Notebook
Gateway laptop MX8734 Notebook will not power up
If it is plugged into the power cord, it will boot up. Radio Shack and Batteries Plus has good deals on batteries and carries most brands.
Mar 18, 2009 | Gateway MX8734 Notebook
Gateway not turning on with or without battery/AC adaptor
these people are right and there is definitely some hardware issues with your computer...which can be repaired but not really worth the money or effort.
Feb 17, 2009 | Gateway MT3705 Notebook
Gateway MX6438 will not power on
if your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
Dec 29, 2008 | Gateway MT6730 Notebook PC
No powerup
Unfortunately, you can't solve this problem. What I have learned as the tech working on a customers gateway mt6451 is that Gateway dropped the ball when they bought a cheap (they spent 5 cents instead of 20 cents) motherboard component that allows the adapter to charge battery and run the notebook without the battery installed, the component seems to have a 1 year if that life. I am surprised they haven't been sued or forced to extend the warranty (like HP had to with their dv8000 series notebooks) althought they would have to replace the motherboard with one that has an improved component on it. How do you sue a company or force them to extend the warranty for a replacement that is made with a better component?
Dec 11, 2008 | Gateway MT6451 Notebook
Computers & Internet Logo
94 people viewed this question
David Payne
David Payne
