Question about Hampton Bay Dryers
I have 2 hampton fans that operate on the same remote. how do i get them to work on seperate hampton remotes?
    Scholar:
  • 113 Answers
Generally speaking, on most wireless fan remotes that I have dealt with there is a spot on the fan "the receiver" and a spot on the remote "which would be covered in plastic". There are four selectors which you can put in the up position or the down position. This basically changes the signal being sent and received. You will have to make them different for each fan, but you must make them the same on the fan and remote that you want to use. This will require you to locate the receiver on the fan and change the code. You will only have to do this to one fan though. If you need more help let me know. Hope I was of some help or at least pointed you in the right direction.
Posted on Jul 31, 2009
Hampton bay fan with remote quit working. Fan does not work with or without remote. It is just dead
  • Disconnect power at the source
  • Remove remote battery and press all buttons to eliminate stuck button
  • Reinstall battery. Apply power to fan
  • Check operation
The remote control may have failed completely
Jun 15, 2017 | Hampton Bay Dryers
Remote for my hamton bay ceiling fan 70 inch model DL-4109S-01 won't work. How can I get it to work?
first off see if the remote is working
if it is a point in the fan direction is is probably infred operation. to check turn on the camera of your mobile phone and point the remote at the lens
if it is working then a white light will appear on the screen of the phone when you press on the remote on button and disappear when the off button is pressed
if that works then it will be in the receiver in the fan
Sep 05, 2015 | Hampton Bay Dryers
Hampton fan model #Model # 68068. Fan has stopped operating using the remote. What is the problem part?
I'm having the same problem with the remote to the ceiling fan. You might want to go to Home Depot or lowes and get a new remote
Jan 03, 2013 | Hampton Bay Dryers
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
Missing remotes for hampton bay ceiling fans
https://www.google.com/search?q=remotes+for+hampton+bay+ceiling+fans&rlz=1C1PQHB_enUS689US689&espv=2&biw=1536&bih=748&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwik3qiMx4bTAhXh5oMKHV3vDJ4QsxgIGg
Apr 02, 2017 | Hampton Bay 52 In. White Redington...
The remote control turns the ceiling fan on and
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Aug 31, 2009 | Hampton Bay 24002 Ceiling Fan
I bought a hampton bay ceiling fan model uc7083t but i didn't
hi there i can help. There is a "dip switch" on nearly all fan remote units, much like a garage door opener has. To keep all the fans in your home from operating at one time, each fan needs a seperate "code". To use your other remote, you need to locate the receiver unit in the fan, usually in the "canopy". This is the bowl looking piece against the ceiling. then note the "code" which is the position of the switches. For instance, most have a block with 4 switches, and if the first is "on", and the remaining are "off", that is it's set code. This "code" can be changed to any combination of "on , off" that you like. BUT, you must also open the remote control and set it's switch to the exact same "Code", or order of "on off" as your Fan receiver. (Usually the control "Dip switch" is in the battery compartment.
Jun 19, 2009 | Hampton Bay 24002 Ceiling Fan
Wall switches do not control fan
Some fans will not operate without the remote, however, I'm not sure if the Hampton Bay brand is one of these or not. Below is how you will bypass the remote if the fan will operate without the remote.
You can try disconnecting the receiver in the canopy of the van (the cover that fits snug to the ceiling) once you have shut off the power source remove the canopy and find the remote receiver.
Most likely it will be a rectangular box with white, black, and blue or red wires attached. Disconnect all wires from the receiver and lay it to the side.
Now reconnect the wires directly to the fan, white to white, black to black, if you have a red wire (or a second black wire) in the ceiling box connect it to the blue wire from the fan.
If you do not have a red wire (or second black wire) in the ceiling box, connect the black and blue wire from the fan to the single black wire in the ceiling box. This method will require you to pull the chain to operate the fan separately.
Dec 12, 2008 | Hampton Bay 52 In. White Redington...
Dryers Logo
44 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
