When the main nozzle with brush rollers is on Kirby Heritage II, it works fine. When I put the hose attachment on, the power light comes on but that's all. Can you help me?
SOURCE: roller brush doesn't move
Here is a online guide....it's for the G series Kirbys. They're similar enough that it should help. Pay special attention to the belt lifting process...it's exactly the same as for the Heritage II, and it's also where I think your problem lies. I have a Heritage II manual available too! Hope I have helped...
Marci
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
SOURCE: no power getting through
Hi
The motor spindle should NOT rotate when there is nothing attached to the front. Its very dangerous. There are two square switches on the front of the machine which engage depending on wether its the main head or hose thats attached. Looks like on of them is sticking
Rob
SOURCE: Roller brush not spinning?
THIS GEEN LIGHT MEANS THAT THE BELT HAS COME OFF. THE REPLACEMENT IS AS FOLLOWS: FLIP THE BRUSH (RUG RENOVATOR) OVER AND REMOVE THE SCREWS ON THE SILVER GUARD THAT KEEPS THE ROLLER IN PLACE. SLIDE THE ROLLER UP OUT OF THE SLOT, TAKING NOTE ON THE HALF MOON SHAPED SIDE. REMOVE THE OLD BELT(OR WHAT'S LEFT OF IT). PLACE THE BELT AROUND THE MOTOR SHAFT FIRST. THEN AROUND THE WOODEN BARE SPOT ON THE ROLLER. PUT THE ROUND(CIRCULAR) SIDE OF THE ROLLER IN FIRST, THEN CAREFULLY STRETCH THE ROLLER WHILE HOLDING IN THE ROUND SIDE IN ONE SIDE AND ROTATE THE ROLLER UNTILL THE HALF MOON LINES UP TO THE SLOT. PUSH IT DOWN INTO THE SLOT AND PUT THE ROLLER COVER BACK IN PLACE AND RE-INSTALL THE SCREWS. AND THERE YOU HAVE IT. HOPE THIS HELPS. PLEASE KEEP ME POSTED. THANK YOU FOR THE HONEST RATING AND FOR USING FIX-YA.
SOURCE: Old Kirby Heritage 2 (Model 2Hd ) won't power on
the power light is a 2 stepswitch make sure when u put yhe power head back on it is locking all the way back if so and not working the switch may have failed
SOURCE: how do you put on the attachment hose?
The Heritage II Legend...First you make sure that the machine is unplugged from any outlet,. Now, raise your height adjust to the highest level. Next you will need to turn your belt lifter on the front of the nozzel to the right as far as you can. Now flip the hinged light cover up, and turn the latch that holds down the head to the left. Your nozzle is now released. Now take the hose and roll it on to the bar from the front to the back, make sure it is aligned and then turn the latch to the right locking the hose, and you are ready to kirby it up! Hope this fixesya! Let me know, Thanks, Rene (the Vacuum Doctor)
