Question about Samsung Epix Cell Phone
I had a password set and it locks every so often when not used. I need to find a way to reset it with no password
Dell xps windows7 home premium, pass word unlock
To reset Windows 7 password with Spower Windows Password Reset, just follow the steps below:
Step 1: Download Spower Windows Password Reset Professional (trial version) and install it in an accessible windows. Spower Windows Password Reset Professional can be installed in windows 2000/xp/2003/vista/7/8/10/2008/2012/2016.
Step 2: Create a Windows password reset disk. You can use Spower Windows Password Reset to create a bootable CD/DVD or USB disk.
Step 3: Set the locked computer to boot from CD/DVD or USB drive.
Step 4: Boot the locked computer from Windows password reset disk.
Plug in Windows password reset disk to the locked computer, and restart it. Wait for a few seconds, Spower Windows Password reset program will start and ready for you.
Step 5: Reset forgotten Windows 7 password with Spower Windows password reset program.
When the Spower Windows password reset program is ready, do the steps below to reset windows 7 admin password:
Mar 11, 2017 | Dell Computers & Internet
Tip
How to Reset HP Pavilion Password on Notebook Computer
Pavilion BIOS password reset is commonly needed. Today, we talk about HP Pavilion Windows password reset solutions. Our Windows OS users can set up administrator account and encrypt it with password to enter the OS. This actually prevents unauthorized users from operating on your system. While, if we Pavilion PC users forget the encrypted password and can't login Windows, now what to do for HP Pavilion password reset?
Firstly, if there are not important files on our HP Pavilion notebook, we can reinstall system by deleting all data and cleaning system. Most of us may hope opt for other ways to bypass the Pavilion login password.
Secondly, please think that is there still another account for us to enter Pavilion PC. In Windows XP, Vista, there is HP Pavilion default administrator which has blank password. For Windows 7, the built-in administrator account is disable defaulted. Only if we set it as enable, the account can be used at the moment.
Take HP Pavilion Windows XP password reset from Safe Mode as example:
a. Press "F8" when Pavilion laptop starts.
b. At the "Advanced Boot Options" windows, choose "Safe Mode" with arrow key and Enter, then PC enters Safe Mode.
c. Click "Administrator" on the Windows login screen.
Note that if we have set this HP Pavilion administrator password, we need to input the password instead of leaving "Password" field blank.
d. Start - Control Panel - User Accounts.
e. Select the locked account and reset password for the locked account.
f. Restart Pavilion laptop and login with the account newly password reset.
Thirdly, the least troublesome solution on Pavilion password recovery is to opt for password reset program tool. With the program and a CD/DVD/USB disk, we can easily remove the password for locked computer. Take Windows Password Recovery Corporation as example:
Step1. Burn .iso file to a CD/DVD/USB Flash Drive on an accessible PC;
Step2. Set locked computer to boot from CD/DVD/USB Flash Drive;
Step3. Recover forgotten Windows password with the burned CD/DVD/USB Flash Drive.
Certainly that the 3 ways can make sure we reset Pavilion password finally. The Windows Password Recovery Corporation can be used for Windows 7, XP, Vista, and Windows Server 2003, 2008 domain password, etc.
Source: http://windowspasswordrecovery.net/article/pavilion-password-reset.html
on Jun 23, 2011 | HP Pavilion dv4000 Notebook
Screen locked and unable to unlock
Turn off . Press and hold POWER + ENTER button for reset menu.
Select
Factory reset with Volume Down button and press Power to reset. All data will be lost! there is an alternate method too friend
Use this method to hard reset your Samsung GT-S Galaxy mini phone: Enter *2767*3855#. Warning! All your data including contacts, messages etc. will be lost! Copy all your necessary data/Contacts/Messages etc. to SIM or make backup to your PC before full reset! Take out SIM card before full reset.
Samsung GT-S5570 Galaxy mini download mode if you want to install eg. Gingerbread
Press and hold Volume DOWN + HOME + POWER ON S5570
Restart your device to clear any temporary software bugs
If you know the hard reset with buttons / keys, pls leave a comment. All comments are welcome!
Your device freezes or has fatal errors
If your device freezes or hangs, you may need to close programs or reset the device to regain functionality. If your device is frozen and unresponsive, press and hold [Power] for 8-10 seconds. The device will reboot automatically.
If this does not solve the problem, perform a factory data reset. In Idle mode, open the application list and select Settings :Privacy
:Factory data reset :Reset phone : Erase everything.
Clear storageā€¢ : Erase the credential contents from the device and reset the password
Set an unlock pattern
Once you set a screen lock, your device will require an unlock code each time you turn it on or unlock the touch screen
Settings Location and security Set screen lock : Pattern
If you forget your PIN or password, bring your device to a Samsung Service Centre to reset it.
Set an unlock PIN code
Settings Location and security :: Set screen lock : PIN
Set an unlock password
Settings Location and security :Set screen lock : Password.
You can hard reset software firmware update your Samsung GT-s Galaxy mini phone
Hope it helps u
Dec 08, 2013 | Samsung Cell Phones
Samsung password reset
Im assuming its a samsung phone
Samsung cell phones come with many security features.
In addition to the common feature of preventing calls after a period of inactivity, some Samsung phones also allow you to prevent others' use of your phone's SIM chip and access to your files.
One password unlocks the various locks, except for two other passwords used for the SIM chip. The syntax of the menu items to click to reset a password differ somewhat between Samsung models but you can figure out roughly how to apply instructions for one phone to another.
Lock the phone from making calls by clicking "Start" or "Menu," "Security Settings" (or "More" and then "Security"), and "Phone Lock" or "Device Lock."
Change the password by clicking "Start" or "Menu," "Security Settings," and "Change Password." Then enter a new password.
Set the phone to work only with the current SIM chip by clicking "Menu," "Security Settings," and "SIM Lock."
Enter a new password when prompted.
Prevent unauthorized use of your SIM card by clicking "Menu," "Security Settings," and "PIN Lock." Type a new PIN when prompted.
Prohibit access to your files, messages and contact list by clicking "Menu," "Security Settings," and "Privacy Lock."
Enter the password from Step 1 when prompted to unlock access.
Reset the file lock/messages/contact password by resetting the phone lock password, as in
Step 1
Jul 25, 2013 | Google Chrome
I have lost my Nokia phone's password how can i
what is Mobile Phone model?You need to reset the old phone password and set new password..To reset the password lock..you can use default code..Try 1234 or 0000 these are default codes...If these code does not works get the master reset code as free of cost from the site Unlocking4free.com/nokia-unlock-tool and reset the Nokia DCT phones from password lock...Then set a new password or security code.
Sep 21, 2012 | Cell Phones
How to reset hp probook 4310s embeded security password
If your hp computer is installed with Windows 7, following the video to learn how to reset hp computer security password with Windows 7 Password Genius
https://www.youtube.com/watch?v=I5HzG7fb-Wg
If your hp computer is installed with Windows 8, and the password is your only admin password, refer to hp computer Windows 8 admin password reset.
Jun 20, 2012 | HP ProBook 4310s Notebook
How can I remove the administrator password of Windows 7?
When you are under account settings, go to administration settings.You have the opportunity to change administration password. If you leave it blank, you won't need a password.
Jun 07, 2012 | Computers & Internet
I cant set the privacy lock ........it shows WRONG PASSWORD......i tried many number but it doesnt work..
What is Mobile Phone brand and Model?
You can reset from security lock or password lock or privacy lock using the master reset code,You can get the master reset code at
Unlock-free and reset from security lock or password lock,Check code for Your model,brand.
Jun 09, 2011 | Cell Phones
How to crack passwords
You can create a Windows password cracker disk to reset your password. Follow this 5 easy steps:
1. Enter a computer that can link to Internet. Search "windows password recovery tool 3.0" in Google. Download and install the software on that computer.
2. Run the software and create windows password reset disk by follow the instructions.
3. Eject the created CD/DVD and insert it into the locked computer.
4. Reboot the locked computer (it's necessary for you to change your locked computer's BIOS setting to make it boot from CD drive) and then follow the instructions to reset password.
5. Now login Windows and set a new password.
Dec 04, 2010 | Video Game Consoles & Games
Password reset
hi.. if you have set a sim lock then u no need to worry about selling ur phone.only if u have made phone lock it cannot be used by other persons.
Jan 22, 2009 | Sony Ericsson W550i Cellular Phone
Open Questions:
I have had a Samsung Epix since July 2009. Love the phone. I am experiencing a problem booting the phone now and have scoured the net and Samsung support team to level 3 and have no satisfactory answer on the fix. I have also checked xda developers. I am hoping that with your experience, you might be able to help or point me in a direction. My phone does the normal start up, (only while plugged in). It gets to, what I'm assuming, is the actual radio (phone) portion of the bootup (led glows red), and then goes dead. As the phone is plugged in to charger, the led which normally glows red, for charge, is now blinking at 2 sec intervals, red and off. Or the other indicator, while charging, is that the led glows a whitish amber. I actually had this happen to my original Epix about 2 weeks after I initially got it, and I returned it to ATT. The next part of the story, is that I actually bought a second Epix on Ebay, and it started showing these symptoms first, and wouldn't boot, but my original Epix still did. (I bought the Ebay replacement to replace the first, because the first had other issues.) Like I said, the first did boot, but maybe 3 days later, it stopped booting and charging also. The Ebay one was in pretty good shape. Thanks for taking the time to read this. I appreciate any help you might have. (Note: I was told by a tech at Samsung level 3 to reflash phone, but it won't even sync to computer with the boot-up/battery issue.) Again, thank you. Regards, Don
Feb 28, 2017 | Samsung Epix Cell Phone
See all Samsung Epix Cell Phone Questions
Samsung Epix  Cell Phone Logo
42 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
