Question about MTX Ford Explorer/Mercury Mountaineer/Mazda Navajo 1991-2001 Thunderform Loaded with 10 Inch Woofer and ... Car Speaker
Door ajar dash light staying on
The 2003 mercury mountaineer that i own is giving me trouble with the door ajar dash light staying on. All doors are shut properly but the interior lights stay on unless i turn them off manually and the alarm will not turn on as well
    Problem Solver:
  • 9 Answers
Your sensor in the door lamb is bad or its the sensor for them
Posted on Jul 31, 2009
How do I stop the door ajar sound from randomly going off while driving down the road in my 2003 Ford explorer?
The switch that turns the interior lights on when you open the door also controls the door ajar sound and light on dash board now that switch
Is either in the door hing or it's a pin switch that sticks out of the pillar post that switch is going bad you have to locate it and replace it hope this helped
Apr 19, 2015 | 2003 Ford Explorer
Doorajar liht and beeper sounds
It can be issue with faulty sensor or a wiring issue.Troubleshooting is required.
Click the help link shown below:---
Door Ajar Light and Dome Light Remains ON? http://whoisbyme.blogspot.in/2012/06/2003-mercury-sable-door-ajar-light-and.html
Door ajar light stays on? http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Thanks.
Jun 26, 2012 | 2002 Ford Explorer
2003 Mercury Mountaineer - door ajar light comes on and the doors are closed. Does not do this all the time.
locate the door thats doing it,, and check the plunger switch in the door thats creating the problem,, it may be just getting stuck,, replace if necessary
May 31, 2011 | 2003 Mercury Mountaineer
Door ajar light doors are closed.
very common check inthe door jam and see if the leaver which is usually black moves freely may have a wire disconnected from that
Mar 08, 2010 | 1998 Mercury Mountaineer
Door Ajar Light
the switches for these vehicles are in the latch and they seize up from time to time. you will have to spray some penetrating oil into the dor and rapidly close and open the door hard to try and fix it. if that doesn't work then you will have to figure out which door it is and replace to latch. note if key is on, the dash will make a tone everytime you open and close door. so the door that doesn't chime that is the door with the issue.
Aug 28, 2009 | MTX Ford Explorer/Mercury...
Door Ajar message comes up even when all of the stores are shut. Interior Lights and Lights on side view mirrors stay on. Lights can be shut off but the Door Ajdar message remains on.
I have this same problem. A mechanic friend told me that basically the grease they use to grease the door latches cause a sensor to think the door is open. He said to buy something thtat will break up this stuck grease, but also has lubricating effects. I forgot what he told me to buy though.
Aug 07, 2009 | 2003 Mercury Mountaineer
02 mountaineer dome light wont go off
Do you get a "Door Ajar" warning? If so that is keeping the light on. On my 03 Mountaineer, the rear hatch emblem has a crack around it that allowed the door sensor to think the door was open.
Apr 22, 2009 | 2003 Mercury Mountaineer
go to your local parts store and buy a can of PB BLASTER lubricant then open each door and spray the latch assembley really good then close and open the door 10 to 15 times. do this with each door. the door ajar light switch is located in the door latch assembley and cannot be seen so soak the latch assembleys really good so lube reaches the switch. these switches sometimes get stuck but this usually frees up the switch
Mar 25, 2009 | 2003 Mercury Mountaineer
2004 mercury mountaineer door ajar light
Ends up being a broken wire(ground) in the rubber boot between door and frame. I carefullly removed door panel, pinched the ends of the boot and slid it back into door. And there it was...a broken black wire. Spliced in a new piece of wire, reassembled everything else. Everything works like it should. It's really not that hard just take your time. Also before I started I disconnected the battery as a precaution. Goodluck.
Apr 01, 2008 | MTX Ford Explorer/Mercury...
Car Audio & Video Logo
530 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
