Question about Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range
The paint around the control knobs showing the heat levels, burner locations etc is wearing off. How do I replace the paint?
  • 98 Answers
Can you find some spray paint to replace it with?...cut the right size hole for the circle in a piece of cardboard...it should have enough cardboard to keep the "spay-over" off the rest of the stove. and then just make small marks to replace the numbers.
Posted on Jul 31, 2009
We installed a mr. heather IR30LPT, set the fan to auto and the control to #1, however, the unit runs continuously without shutting off. The room is less that 1000 sq. feet. Can you tell me why the unit is...
THERMOSTAT CONTROL OPERATION
FOR IR20LPT / IR30LPT: The thermostatic control used
simply turns on and off the burner.
FOR BF20LPT / BF30LPT: The thermostatic control
used modulates the flame size as the temperature gets
closer to set point, then it turns off the burner upon
reaching temperature.
The burner will cycle back on when room temperature
drops below the set temperature. The control knob can
be set to any heat level between 1 and 5. Selecting the
HI setting will cause the burner to remain on.
Note: The thermostat sensing bulb measures the
temperature of air near the heater cabinet. This
may not always agree with room temperature
(depending on housing construction, insulation
location, room size, open air temperature, etc.).
Frequent use of your heater will let you determine
your own comfort levels.
The LED temperature indicator measures approximate
room temperature around the heater.
Note: The LED temperature indicator DOES NOToperate with or control the thermostat setting of the
heater.
IF YOUR UNIT IS NOT TURNING OFF IN POSITION 1 BUT THE TEMPERATURE AROUND IT IS HIGH THAN THERMOSTAT IS STUCK AND YOU HAVE TO CHANGE IT OR VISIT SERVICE.
1-5 knob has no info what is the parameters of temperature sorry!
Nov 27, 2017 | Heating & Cooling
RHFE Rinnai 551FT gas heater is not working after 7 years
see this steps and fix it. God bless you
If there is no heat, check the electrical service panel for a burned fuse or tripped breaker. Relight the pilot light (see below).
If there is not enough heat, adjust the burner air shutter (see below); and clean the burner ports (see below).
If the pilot light does not light or does not stay lit, clean the pilot orifice carefully with a toothpick, test the thermocouple and replace it if it is faulty (see below).
If the flame flickers, adjust the pilot (see below).
If there is an exploding sound when the burner ignites, adjust the pilot to a higher setting and clean the pilot orifice and the burner ports.
If the burner takes more than a few seconds to ignite, clean the pilot orifice and adjust the pilot light.
If the burner flame is uneven, clean the burner ports. If the burner flame is very yellow, clean the burner; open vents in the furnace room to provide more air; adjust the burner air shutter.
To light the pilot on a standing-pilot (always on) ignition system, follow the lighting instructions located near the control. Otherwise, try these steps:
Light the pilot:
  1. gasfurnace1.jpg Press and hold the pilot control knob to start the pilot. Set the control knob to the pilot position. Hold a long match under the pilot gas port.
  2. Press the control knob; the pilot should light. Hold the control knob down until the flame is burning brightly (about 30 seconds). Release pressure on the knob, and turn it to the on position.
  3. If the pilot goes out when you release the control knob, try relighting, holding the control knob down longer. If the pilot again goes out, check the thermocouple (below).
Adjust the pilot:
  1. Remove any cap covering the pilot adjusting screw on a combination control.
  2. Turn the adjusting screw counterclockwise to increase the flame or clockwise to decrease it. It is correctly adjusted when the flame envelops the thermocouple bulb by 1/2 inch and appears dark blue with a small yellow tip.
Test and replace a thermocouple:
  1. Hold the control knob to pilot and light the pilot as above.
  2. Unscrew the thermocouple fitting with an open-ended wrench.
  3. Set a multimeter to the DVC (lowest voltage) scale.
  4. Clip one multimeter lead to the end of the thermocouple tube nearest the pilot and the other lead to the fitting on the other end of the tube.
  5. If the multimeter shows a reading besides zero, the thermocouple is functioning. Replace the thermocouple tube.
  6. If there is no reading, you will need to clean or replace the thermocouple following steps 7 through 11.
  7. Release the control knob and shut off the main gas valve on the gas-supply pipe that leads into the burner. Shut off power to the burner at the electrical service panel .
  8. Remove the thermocouple from its mounting bracket.
  9. Wipe the combination control clean and install a new thermocouple, tightening it by hand, then give it a one-quarter turn with a wrench.
  10. Insert the thermocouple into the pilot bracket, being careful to not crimp the tubing.
  11. Turn on power to the furnace and relight the pilot (above).
Adjust an adjustable burner air shutter:
  1. Set the thermostat to its highest setting to keep the burner running. Once the furnace has heated up, remove the burner access panel and loosen the locking screw.
  2. Open the shutter by turning it to the right until the blue base of the flame appears to lift slightly from the burner port surface. Then close the shutter until the flame reseats itself on the surface.
Clean removable burner tubes and ports:
  1. Shut off gas and power to the furnace.
  2. Unscrew or loosen and remove the tubes from the supporting bracket.
  3. Carefully clean the tubes with a brush or vacuum, making sure not to damage the burner ports.
  4. Use a stiff wire to clear any debris from clogged ports.
Sep 30, 2012 | Heating & Cooling
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Aug 24, 2011 | Ducane 30400040 Stainless Steel Grill
Maytag gemini gas range--3 burners wont light, they don't get the signal to light when you turn the burner on. They do light if you turn on one of the burners that work and one that doesn't at the same...
Hi, there is a switch on each burner control knob shaft. These switches wear out and are easy to replace once you remove the panel over the knob area. Each switch has 2 wires plugged into it and costs around 5 to 10 dollars. Any switch causes all burner electrodes to spark. Good luck,
Feb 23, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Both heating elements in the oven not working. I did inspect the h. elements found no burn. thankyou help
Ok, you can confirm element failuer by testing for continuity with a Ohm meter. A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Another reason, why the elements would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
If the elements show continuity, you will need to replace the entire control board(clock, EOC)..
Jun 01, 2009 | Frigidaire Kitchen Ranges
Main Burners completely rusted out; control knobs to burner...
Get replacement burners and preheat them once. Then paint them with high temp enamle paint to withstand the temps of the grill. The burners are regular untreated steel and not the stainless that one would expect. Painting them will prevent them from rusting out after 2 years. Just make sure you temper them once before you paint them as they will expand a little. Then paint them and enjoy!
Apr 26, 2009 | Frigidaire GL38LKEC (LP) Grill
VGSU 36" gas cook-top control panel paint coming off
I just bought a bank repo home in So. Cal. that has the same Viking range as you have. Yes, the black lettering has almost entirely rubbed off. on this one too. Not good for such an expensive product.
I bit the bullet and ordered a new panel from appliancezone.com
http://store.appliancezone.com
Part # PE40057
The price is about $75, $80 with shipping, which is a ripoff I know.
I plan to put a clear coat of sealer on it and let my wife know to treat it gently.
I was surprised how many people think Viking products suck. Lots of negative reviews abound on the internet. If I was to buy a whole new range I think I'd avoid this brand.
Cheers,
Andy Dale
Apr 22, 2009 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Electric range surface light stays on
When the burner went, it took out the switch that controls it. The contacts inside the switch have welded together. That switch needs to be replaced. You should also look at the receptacle that the burner plus into. That may have been the original cause of all the problems. The contacts in them often wear causing the burner to src inside the receptacle. These parts should be readily available from Sears: burner control (infinie) switch, Burner receptacle.
Apr 09, 2009 | Kenmore 91112 / 91114 / 91117 Electric...
Replace burners
remove the cooking grates and the 5 pieces ubnder the grates covering the burners from the grill. Next remove the 4 screws on either side of the control knob panel pull it away from grill and pull the burners out from inside the grill. DO the reverse to install new burners
Apr 19, 2008 | Ducane 30400042 (LP)
Burner light does not go off on Amana AKT3040
Sounds like a short in that particular burner circuit. Usually when the light stays on even after cool down the heat sensor is bad. This is inside the burner. If your getting white smoke the burner switch could also be shorted out.
Apr 05, 2008 | Amana AKT3040 Electric Cooktop
Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range Logo
289 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
