Question about Eureka 4700A Maxima Bagless Upright Vacuum
I was vacuming and it stopped running. will not
I was vacuming and it stopped running. will not power up
  • 40 Answers
Either you have a break inside the power cord or the wires have come loose on the motor.
Posted on Aug 01, 2009
Oreck vacum steamer stopped steaming
Probable failure of the steam generator
Jun 03, 2014 | Oreck steam-it Stick Vacuum
Hand held vacume stop working after 1st use
go please to the web for instructional videos and maintenance help
God bless you
http://www.bissell.com/how-to-videos/
Jul 19, 2012 | Bissell 3594 CleanView PowerTrak Bagless...
Dirt devil doesn[t hold charge
Try running the battery all the way down by letting the vacume run in a corner or another room and even when it stops leave it on for a hour to drain the battery. Then shut the switch off and try charging the battery. Make sure the charger is putting out enough volts by looking at the rated output of the charger and while it is plugged in check it with a volt meter. If it does not hold a charge and the charger is putting out the right voltage you need to purchase a new battery for the vacume
Mar 18, 2011 | Dirt Devil Easy Lite Quick Vacuum
My Hoover vacuum cleaner is not picking up from the carpet like it used to. Like it's having difficulty picking up strings, fuzz, etc. from the carpet. Suction power seems to be fine. The belt and the...
YOUR VACUME SHOULD HAVE A HOSE THAT PLUGS INTO THE LOWER PART OF THE VACUME OR MAY COME APART AT THE BOTTOM . IT SOUNDS LIKE THE TUBE IS STOPPED UP AT THE FAN MOTOR
Jan 16, 2011 | Hoover Vacuums
Hi My Electrolux Oxygen Z5530 stopped working from one second to another. No lights - nothing - totally dead. What can I do? Is there any fuse? Sincerely Eva
I have same problem and I check it out.
The special requrement of Electrolux for his vacum cleaner motors is that they working with high reliably approx 800 hours working time and no more!!! (it should stop safe with no danger for users...)
7 years has past (2 h/week x 52 x 7 = 708 working hours) so it is time for us consumers to buy new vacum cleaner...
Jan 05, 2011 | Electrolux Vacuums
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 | Vacuums
It stopped running while vacuming and would not start again
The most likely problem is the cord end is broken, it is cheap to replace if you do it yourself. if it is a plorized plug ( one blade is bigger than the
other ) pay close attention what side the wires go to and match them on the new one.
Nov 16, 2009 | Vacuums
When i conect the vacum part to maun system it
There is a motor in the power head that could be out or the receptacle, electric cord on power unit or loose wire in power head.
Oct 14, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Fantom vacuum
sounds like a partly clogged filter
Mar 10, 2008 | Fantom Vacums FM741 Twister Bagless...
Vacums
check belt not broken - could have happened when you caught tassle in head
Apr 18, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Eureka 4700A Maxima Bagless Upright Vacuum Logo
210 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
