Question about Samsung SCH-U470 Juke Cellular Phone
My juke screen stays white
When i torned my phone on the creen stay ed white and never turnd to my back round
The monitor worked fine when we received it several months ago. Recently it started going all white, except for a few very thin colored vertical lines. I could shut it off wait a few seconds and torn it...
If this is still under warranty, then send it back for repair. If you have connected it to 2 PCs with the same results, then the problem is internal to the monitor.
Oct 20, 2010 | Computers & Internet
It stays on a white screen when I turn it on
hello,its a screen problem,all you need to do is just to get a brand new screen and fix it up.i will advice you take it to an expert to help you fix it so as not to compound the problem.
Take care.
Apr 10, 2010 | Samsung X820 Cellular Phone
When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
Nov 26, 2009 | Motorola Mobility RAZR V3
Goes right to a white screen and stays like that
transfer all your contacts and pics to ur computer and go to phone , then security , then press reset , enter your code which is the last for digits of ur number unless u changed it and it should work , when you unplug battery for about 2 days , to be safe
Sep 27, 2009 | Motorola Mobility Rival A455 Cell Phone
I have a I855 it turns on but the screen just stays white
it can also be the ribbon between the screen and the motherboard. these phones (i855) seem to have that proble alot!!
Jul 09, 2009 | Nextel BOOST i835g i835 LTD. ED UNLOCKED...
Hhhhhhhhhhheeeeeeeeeeeeeeeellllllllllllllllllllllllllllllllpppppp
I used to have this phone. Best tmobile phone ever. Take off the battery hatch and battery, and look for a round red sticker, if you don't see one, Don't panic, That means your phone isn't water damaged. If you find a white round sticker, hen your phone isn't damaged by water and it is an internal problem. Get me back ~miikee
Jun 12, 2009 | Nokia 5300 Grey Cellular Phone
Won't stay closed
i am pretty familiar with the inside of that springed hinge...its a round spring (obviously) but you should probably take it in...if its under warrenty 'cause that seems like something someone wouldn't be able to fix to easily...or you could also tape it
two rules to life. its its stuck and it ain't supposed to be WD-40 it, if it ain't stuck and it's supposed to be ducktape it
May 16, 2009 | Verizon Communications Samsung Juke Cell...
Samsung juke broken
you may have broke the spring it is fixable but it may cost a pretty penny if your not doin it yourself carefully take the phone apart there ar screw behind the battery and look just inside so if anythings broken if so take it to verizon so they can get you that part
Apr 21, 2009 | Verizon Communications Samsung Juke Cell...
My phone is being stupid
have u tried a master reset on it
Dec 21, 2008 | LG Prada KE850 Cellular Phone
Samsung SCH-U470 Juke Cellular Phone Logo
101 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
