If you take your Registration document into your local dealership, they will give you the code for free. Or you can buy to code for about $12 to $18 from a Radio Code seller online by giving them the make and serial number.
Also try this
The car radio code is indicated on many Mitsubishi models on a small white sticker inside the glove box. The unlock code will be labeled "Anti-theft radio code"
Aux Input and Echo Devices Aux input requires a 3.5mm auxiliary cable and a device with aux output capabilities. You may recognize the aux cable as the same type of plug that comes on a standard pair of headphones. An aux input amplifies audio from the output source.
Make sure whatever is plugged into the Aux port is the proper size and configuration (2-lead, 3-lead; 3.5mm, etc) as far as the cable, is properly seated (not so big that it doesn't fit all the way in) and that the device is on. Most Aux inputs don't activate unless there is an active signal coming in.
I know its a little but I had same problem with mine power to unit but wont turn on. I removed the stero removed the plug then hold down the button with return writte under it ( I think its number 3) then plug it back in. as far as the unlock code If the car is registared i8n your name ring Misibishi with thye VIN number they should be able to help you out.
On the back of this system, do you see a group of RCA plug outlets? Marked IN and OUT? Phono IN? Phono OUT? Speaker IN? Speaker OUT? CD IN? CD OUT? Look for the one marked AUX IN or AUX OUT. AUX IN lets you connect a separate device, could be colored Blue, Green, White. Usually paired one over the other, RED over WHITE, YELLOW over WHITE, ect. If this system will accept an auxillary unit, player, ect, then it will have an AUX RCA type plug on the back.
hello..i think that.aux in this case is an output..you can try this through connecting your amplifier to any of the aux outputs... and play a cd ,sorry..good luck ..Ron.
