FixYa.com
Tags:
Sewing Machines
Generic problem for all Sewing Machines
Se270d brother sewing machine
posted by japhillips on Nov 24, 2007
Is it possible to start a pattern in the middle....without starting all over if it has messed up on the last step
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 20, 2008
Not Rated (0)
Pittsjanec
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It is easier to use the help menu and forward search through to the color you stopped at the use the your forward button to go stitch by stitch till your where you need to be.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Nov 25, 2007
Not Rated (0)
allmakes
Rank:Wiz Wiz
Rating: 84%, 1156 votes
Yes, where you left off at the last bit of pattern, take the material out and get a piece of waste material and go through the pattern until you know where you need to start again, take the waste material out and put your material back on and continue but you will need a good eye
This Problem Also Relates To: Kenmore 19233 Computerized Sewing Machine Kenmore 11206 / 11306 / 11506 / 11606 Kenmore 15202 Mechanical Sewing Machine Kenmore 15408 As Seen On TV Handy Stitch Mechanical Sewing Machine Brother LS-2220 Mechanical Sewing Machine Brother XL-2600I
Can you Help with these Sewing Machines problems?
Sewing Machines
europro model ep150
Sirs, I bought a used Ep150... Answer This...
Brother XL-6562 Mechanical Sewing Machine
Brother XL-6562 Mechanical...
The reverse sewing lever (page... Answer This...
Singer 7462 Mechanical Sewing Machine
Button Hole Beeping on 7462
Every time I try to sew a... Answer This...
Baby Lock Ellure
baby ellure model esl
lcd display screen is... Answer This...
PfaFF Quilt & Craft Pro 7530
pfaff hobbylock serger 784 786
Troubleshoot timing problem.... Answer This...
Repair Service
Find Sewing Machine Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
