Question about Genius G-Pen F610 (31100050100)
Drivers don't install on macs OS10.5.7
Drivers V1.66 and V1.71) supplied with G-pen f610 graphics tablet do not appear to install on the mac OS 10.5.7. Annoying! Can get something out of it but can't access pressure parameters in illustrator.
  • andrew731 Jul 31, 2009
    thanks - it is for the mac
  • 555 Answers
Please check if your driver is supports the Mac OS then if it is not supported by your current system please find or download driver that supports the MAC OS. You can search using www.google.com.
Thanks
Posted on Jul 31, 2009
  • Jonas Awayan
    Jonas Awayan Jul 31, 2009
    If it is Mac support then try to scan the installation notes/instructions to able to fix the problem. also visit www.google.com to search more techniques and procedures bout the installation of any software with Mac OS Supports.
    Thanks
Pen is slowish and difficult for detail work. seems to be what I would call hurky jerky in the details. Intous 3 graphics tablet Model PTZ-431W
1. Make sure appropriate drivers are installed. e.g. If Windows version is XP, the driver should be for
XP.
2. Calibrate your digitizer/graphic tablet according to your requirements. This link should give you
an idea on how you will set your pen.
http://www.khulsey.com/wacom_tablet_tutorial.html
NOTE: Illustration is for Mac but it is similar with Windows.
Jan 16, 2011 | Wacom (PTZ930AC) Graphic Tablet
Replacement Pen for G-Pen F610 isn't working very well.
nomally happens the 1st time you use.
log off and back on again.
otherwise reset ... it should work next time you boot up.
Jul 21, 2010 | Genius G-Pen F610 (31100050100)
G pen 450 not working with photoshop cs4 in mac osx
Double click pen tablet icon in system try,then open button tab,under
button command change Button Name from Pen Tip ( Default ) to Barrel Button 1 , click Ok and in Ps from Window meni select brushes,click Shape Dynamics (letters not square) and from shape dynamics dilog move Minimum Diametar slyder to right ( 100 %).This solved problem to me.I hope it will work for anyone else.I run xp sp3 on Windows.
Jun 24, 2009 | Genius G-Pen F610 (31100050100)
G-Pen 610 install disc won't install tablet on MacBook Pro 2.2
hi there... Good news.. problem solved.. i was facing the same problem like thousands of others. not able to install the tablet f610 on to my macbook pro.
the solution turned out to be simple....
i went to the genius site.. go to products... tablets.. and under there somwhere u will find dowloads link... just download the  driver that you need.. ..
it will work.
best of luck
peter dsouza
Mar 29, 2009 | Genius G-Pen F610 (31100050100)
G-PEN F610 on iMac
When I installed the software, it never got to the "Software successfully installed" screen, but kept going through the installlation phase. As I looked in the manual, I saw that the last message one should get is "Restart your computer." I do not have CS3, butin the programs I have used I have not had any trouble with the pen. HTH
Barry
Feb 25, 2009 | Genius G-Pen F610 (31100050100)
Problem with g-pen 610
it will work.
best of luck
peter dsouza
Feb 21, 2009 | Genius G-Pen F610 (31100050100)
G-Pen F610 blind spot (pen won't move over particular section)
Sometimes it is caused by a metal plate coming in contact with the sensor pad inside of the tablet. It is only fixable by dismanteling the tablet and putting an A4 sheet of paper between the back side (the one that has the metal plate which can be the culprit) and the green pad (do not touch it!). This issue usually appears after continuous use when the green sensitivity pad is pushed down a little and is short-circuited by the metal pad on the inner side.
Dec 28, 2008 | Genius G-Pen F610 (31100050100)
Driver for mac
Hi, this is Erik Thau-Knudsen (from Silkeborg, Denmark, by the way) back again. The problem was with the local importer (AGK Nordic), not with the tablet itself. Some googling brought me to the Mac OS X file itself, located at http://www.uc-logic.com/download/driver/OS%20X_PenTablet_Driver1.24.zip.  On the download page http://www.uc-logic.com/download/download_driver.htm, you can find device drivers, written for the following operating systems:
  • Microsoft Windows 98
  • Microsoft Windows ME
  • Microsoft Windows NT
  • Microsoft Windows 2000
  • Microsoft Windows XP
  • Microsoft Windows XP64
  • Microsoft Windows Vista
  • Apple Macintosh OS 9
  • Apple Macintosh OS X
Thank you for your tips, notably about the manufacturer.
Erik Thau-Knudsen
Jul 08, 2008 | UC-Logic WP5540U (689076312929)
Pen pressure and scale problems
I also use Intuos 3 tablet, did you already try replacing the tip and reconfiguring the pen to the screen? You can find this in the driver software, it synchronizes the pen and tablet.
If you already tried that, does the problem only occur in Photoshop? Also, check your brush preferences, you can go back to your default settings and see. If talking to Wacom fails, you might have a bad pen or tablet.
Jul 07, 2008 | Wacom Intuos3 4x5
Driver for mac
I struggled with this tablet on my mac for a while now. Yesterday, I contacted service@uc-logic.com and got a prompt reply. Here is a link to the latest driver. Seems to work with Photoshop CS4.
http://www.uc-logic.com/download/driver/OS%20X_PenTablet_%20Driver1.24.1.zip
Please kindly uninstall the previous driver (GO-->Applications-->PenTablet Setting-->Uninstall
PenTablet Driver) before you install the new driver.  Thank you.
Besides, please do not plug the tablet into pc before the driver installation is done.
No restart is necessary, at least for me.
Jul 15, 2007 | UC-Logic WP8060U (689076313025)
Open Questions:
See all Genius G-Pen F610 (31100050100) Questions
Genius G-Pen F610 (31100050100) Logo
797 people viewed this question
Top Genius Computers & Internet Experts
micky dee
Alun Cox
Are you a Genius Computer and Internet Expert? Answer questions, earn points and help others
