Question about Dishwashers
Dishwasher is not working. No power. I checked the electric box and everything is fine. Pulled dishwasher out, and it seems to be plugged in.
  • 10,865 Answers
If your dishwasher doesn't work at all, check these:
Power from the house
Door switch
Wiring
Timer or selector switch
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on Jul 31, 2009
No power to my dishwasher. I checked the electrical panel. It's fine.
So the panel is fine - so what! Did you check the power line that feeds the dishwasher? Is it directly wired and not plugged in? Did you use a volt meter? Did you check the wiring for bad connections/ breaks?
Aug 23, 2017 | Dishwashers
Our whirlpool dishwash is not cleaning the dishes very well so I pulled it out from the wall and un hooked the electrical and the water lines. After looking at it I hooked everything back together and I...
I've installed many DW's and haven't seen a reset on one. Take in mind, not saying that they're couldn't be one, but I doubt it IMHO. I've been installing all appliances proffessionally for 10 years and it just doesn't seem like there could be one.
Have you check your washing machine plug behind the machine to see if it's a GFCI plug? I've seen it happen where a consumer had done something electrical in the home and it tripped. They bought a new machine and we showed them that it was the outlet, they didn't even know that they had one behind the machine. I know this doesn't help much but good luck in the problem solving.
Dec 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Everything was working fine stopped during wash and did not drain the water
I had a similar problem with mine. I unplugged it from the electrical outlet and plugged it back in. It seemed to reset something.
Oct 27, 2010 | Kenmore 16483 Built-in Dishwasher
I have a DU943PWKB0 Whirlpool Dishwasher that will not drain. It appears to be opperating but the unit will simply not drain the water. Could be the pump or possibly a clogged drian I guess. How can I...
MOD DU943PWKB0 WHIRLPOOL PROBLEMS
My Whirlpool dishwasher is not working. I pulled it out and when I leaned it forward it seemed to work once againe, but once I placed it back into it's slot it would not come on. Checked the wiring and everything seems fine. Unsure of what i should do.
Mar 04, 2010 | Whirlpool Dishwashers
My dishwasher wont start
Sounds like you need to check for power to the unit. Access is at bottom of dishwasher under panel. Next you will see the wiring coming into an enclosed electrical box. you will need to get to wires and check voltage on black hot wire to neutral with a voltage meter. If you have power but still doesn't work then at least you know the problem is with the unit and not the incoming power.
Jul 24, 2009 | Dishwashers
Won't drain, no power
replace water pump at the bottom of the unit costs about $40.00
Jul 09, 2009 | Dishwashers
No electricity getting to dishwasher
check connection at connection box under dishwasher behind lower pannel was ther power to the switch some dishwashers have a thermal fuse in the console white plastic whith two wires going to it
Jul 02, 2009 | Westinghouse Dishwashers
GE 2200 Dishwasher-no power at all, circuit breakers are fine, switch works
with your volt/ohm meter check for power going to the dishwasher. the power supply is located under the kick panel. the power wire may be shorted out due to poor installation. if you are not comfortable testing power, I would advise calling a professional. If no power is found at the power box (this has a power cord or electrical wire going to it) the problem lies within your house electric. if 120 volts is present, check for power @ the door switch. aftrer that you just need to follow the power wire and see where it stops
If this is a newly built house and new to you the builder may have put a light switch above your counter ,the one you didn't think went to anything, check for that! good luck with it!
Oct 16, 2008 | Dishwashers
Computer does not turn on
Check the switch of the power supply at the back (black button) First
If the power supply fan doesn't work or cpu fan doesn't work
Replace the power supply.
Thank you for using FIXYA
Please don't forget to rate my help
Have a great day!
Pablo :-)
Oct 16, 2008 | Computers & Internet
Bosh dishwasher does take electricity
MAKE SURE THE DOOR LATCHING MECHANISM IS OKAY IT HAS A SAFETY POWER SWITCH CONNECTED TO IT
ALSO USE VOLTMETER TO MAKE SURE THE AC SOKET ITS CONNECTED TO IS GETTING POWER
Jan 10, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
104 people viewed this question
Top Dishwashers Experts
