Question about Indesit 24 in. DI67 Free-standing Dishwasher
DI 67 will not fill
HI: I am a single woman who likes diy. First I broke my outhose while trying to clear a blockage in it. I ordered a new one and replaced it: no problem. Then I had to reconnect the inlet hose because it was too short to allow the machine to be pulled out...and I broke that. So I replaced that with a longer one, ran a soak cycle, no problem. Pushed the machine in place, left it a couple of days and now, lo and behold, I turn it on and it will not fill. No noise other than the beep beep beep for the resetting each time I turn it on and off and reset. Anyone out there who knows what caused this????
Re: DI 67 will not fill
I have solved my problem: I checked the water hose etc...all worked fine. I unscrewed the float valve (difficult to put it back, have to use pliers to pull it up and then scissors to hold it in place while screwing the top back on. Magic! It worked!!!
(the float valve is inside on the bottom, behind the spray arm- but if you have already unscrewed everything to access the base of the dishwasher then the best thing is to leave it on its side with the door open so that you can access both the top and the bottom of the valve (you will need a helping hand). Good luck!!!!!
Posted on Nov 25, 2007
0 characters
3 Points
Dishwasher wont fill after a blockage.
search for an appliance repair manual or user guide for your particular machine online. most machines have a manual available as a PDF file that's free to download. check online.
Jul 14, 2015 | Dishwashers
Samsung DMT400 continuous drain and fill
We had the same problem and thanks to a woman who posted a solution in January, we were able to fix it at home at no cost. The solution is to pull out the unit, remove the panel on the left side of unit, tap on the clear box that is at the bottom of the unit ~ it has a float in there that got stuck, therefore signalling the dishwasher that there is a low water level. After tapping on that, the float came back up to the top of that clear box (we started the dishwasher before this procedure in order for the water to flow into the dishwasher). That's all it took. I then put a cup of white vinegar into the dishwasher to clean some of the gunk out of the unit. Our unit is only 1-1/2 years old. Hope this helps.
Apr 22, 2014 | Samsung DMT400RHS Builtin Dishwasher
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Indesit DI 620 which won't drain water
this appliance is a built in dishwasher and may have somthing jamming the pump,this can only be acessed from the bottom and may require the appliance being removed,also check that there is not a blockage at he sink.
Apr 19, 2009 | Indesit 23 in. DV62 IX Built-in Dishwasher
Ariston Dishwasher LSV 67 AIX wont fill with water pumps out only
somebody is pulling your leg.
messy filter will not cause no fill as long as machine has drained tho it will cause other problems
Jul 15, 2008 | Dishwashers
Tecnik dishwasher tkd795/3
your machine has flooded and has trippedthe flood switch in the base of machine which turns on the pump to drain and that is the noise you hear
you will need to find cause of problem which is possible leak in machine
Mar 21, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Hotpoint ultima DF32
please post the complete model number off the unit
Jan 27, 2008 | Dishwashers
DI 67 Diswasher trips RCD fusebox
either the element is faulty or poss the electrical filter.
Nov 14, 2007 | Indesit 24 in. DI67 Free-standing...
Indesit Di 67
Tilt your washer forwards. Water will leak from the front but once this has cleared your dishwasher should be ok again. I paid an engineer to come and tell me this. If your dishwasher is not completely level this can sometimes happen. Hope this helps.
Oct 18, 2007 | Indesit 24 in. DI67 Free-standing...
DI 67 S fault
Try to tilt your dishwasher forwards. Be aware that water will leak out of the front. Once this is clear it should work. I paid an engineer to come and tell me this. If your machine is not completely level it causes it to over fill and after a time will not work. Good Luck
Sep 28, 2007 | Indesit 24 in. DI67 Free-standing...
Indesit 24 in. DI67 Free-standing Dishwasher Logo
140 people viewed this question
Top Indesit Dishwashers Experts
Ted Maxwell
Andrew Taylor
Andrew Taylor
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
