Question about Refrigerators
How do you remove the water input valve from the filter assembly? It doesn't have a typical threaded connector, but a snap-on connector.
  • 560 Answers
It is either a push in and twist CCW to release, or it is a compression sure lock push in style with sleeved jaws that grip the lines and require a insert tool to spread the coupling jaws while pulling the connector straight away from the filter.
Posted on Jul 31, 2009
Water is not coming out of dispenser........
HI. First, you will need to rule out any standard issues that will cause this. Check the internal, and external feed lines for any obstructions. Make sure that the internal lines are not frozen, or kinked. If the lines check out ok, move on to the water filter(if equipped).
In most units, there will be a filter, present. These devices are set to operate on a particular time frame. If their filtering limit is met, the filter will stop filtering water, thus, not allowing the fluid to flow, at all. Make sure that the filter is up to date. If you have verified that the filter is ok, move on to the water inlet valve assembly.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Aug 15, 2010 | Samsung Refrigerators
Water dispenser does not work. Bought in 06
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to Remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. the multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Mar 01, 2010 | Whirlpool Refrigerators
Got a problem with my SmartWater filter. the water stopped, I then replaced with a new filter. but there is no water neither. and also there is water leaking out when the filter was taken down.
HI. There may be some issues here with the actual inlet assembly. it must be inspected thoroughly. Follow the procedure below to assist with this issue.
Dec 07, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water doesn`t shut off to the ice maker. is the problem in the solonoid?
Yes. the solenoid is stuck open. Use the procedure below to address this issue further.
Nov 23, 2009 | Frigidaire Refrigerators
No water comming out and no ice. checked line in back of frig and water going in. what to do?
HI. Check the filter date, if equipped. If the filter has reached its filtering limit, it will not allow for the proper flow of fluid. replace the filter if needed. Ok, if the filter is not an issue, i would advise to inspect the internal lines. Make sure the lines are not frozen over. this will constrict the flow as well. If the lines are ok, this will lead to a failed inlet assembly. Follow the procedure below to inspect the water inlet valve.
Nov 17, 2009 | GE Refrigerators
Water problems
Hi. the first action is to check the water filter(If Equipped). Once a water filter reaches its filtering limit, it will stop the free flow of water immediately. This will require you to replace the filter asap, if needed. Once the filter is replaced, the water will flow freely once more. I would also advise to check the integrity of the lines. If the lines are frozen, this will cause a no-flow situation , as well. check to make sure that the lines are not frozen.
Ok, if the lines and filter are not the issue, kindly,proceed to the inspecting of the water inlet valve assembly.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink, or behind the unit). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.../
Nov 16, 2009 | Refrigerators
Water not making it to ice maker
HI. I would advise to inspect the water valve assembly. This will be the likely culprit.(Make sure that the lines are not frozen, and the water filter, if equipped, has not reached its filtering limit, before proceeding)
Nov 07, 2009 | Kenmore Refrigerators
The water doesn't come out of the fridgerator
HI. Check your water filters date on the capsule. If it is more than 10 months old, this will be the culprit. If the water filter is not more than 10 months old, i would then advise to test the operational value of the inlet assembly.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Oct 15, 2009 | LG LRSC-26922 Side by Side Refrigerator
Water on freezer door not working
HI, i would advise to check the lines to see if they are frozen over, if the lines are not frozen over, this could also be a filter issue. Most water filters that have reached there operating limit, will not continue to allow the flow of water to pass through, replace the filter if it is needed. If you do not suspect any filter issues, and the unit dose not have a filter, i would move on to the water valve assembly.
Sep 21, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
My 7 year old Kenmore refrigerator is not dispensing water and ice.
HI. there are only two reasons for this type of issue. One would be a frozen water supply line and reservoir, and the second reason will be a faulty inlet valve assembly. IF you are certain that the lines are not frozen, i recommend replacing the inlet valve assembly asap.
Use this procedure below to test the valve.
Aug 24, 2009 | Refrigerators
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
