Question about Zanussi Dishwashers
Model LS14EA/INS has fault C 8 on display. what
Model LS14EA/INS has fault C 8 on display. what is this
USER GUIDE FOR ZANUSSI Ls14EA
Let us know if this is the correct guide or not, using the Comment menu.
http://kitchen.manualsonline.com/manuals/mfg/electrolux/ls14.html
May 14, 2018 | Zanussi Washing Machines
How many inches equals 68mm
2.677165 ins which is very close to 2 5/8 ins.
Mar 02, 2015 | Sewing Machines
How do i change faulty tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 23, 2014 | Vizio L32 32 in. LCD HDTV
Sony xperia troubleshooting
I don't knwo if your problem is troubleshooting or 404error
1-solution for troubleshooting:
No plug-ins are found
  • For some phone types and in some countries, there might not be any plug-ins for the LiveView application.
Your LiveView micro display is automatically turned off
  • The battery level is too low. Charge your LiveView micro display.
  • Pairing failed. Enter pairing mode again.
Unexpected behaviour
To reset your LiveView micro display:
  1. Make sure that your LiveView micro display is turned off.
  2. Press and hold the Power key for approximately 8 seconds until your LiveView micro display is turned off again.
The phone media player cannot be controlled from LiveView
  • LiveView supports the standard Android media player. If your phone manufacturer has removed the standard Android media player, LiveView will not be able to control it.
2-solution for 404error :
A/
clearing the PROXY in the APN settings. If you're on ICS, do the following. Open the Settings > More... > Mobile Networks > Access Point Names > [Your APN Name] > Proxy - clear this field.
OR
B/System Settings > "More..." in Wireless and Networks > Mobile Networks > Access Point Names (APNs) >press the menu button, inside the menu press "Reset to default" > now another option will appear called "Internet 3G" (modem) , besides the "Portal 3G". Choose the new option "Internet 3G" and you are done!
Good Luck
Jul 04, 2014 | Tablets & eReaders
Engine light came on after car wouldn't start in the cold
It sounds like a fault in the display board inside your dash. Is the car running normally now? If so, wait till weather warms up and see if the 8 turns back to normal.
Jan 08, 2014 | 2008 Chrysler Town & Country
I have an f2 error code on my kenmore oasis washing machine model number 110.2803
HI,
You have a extended drain problem. Most likely you drain pump is clogged and causing your unit to fault out after 8 minutes of attempting to drain.
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Read more:http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Sears / Kenmore Fault Codes#ixzz1WKO5b8KR
I hope this helps.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 | Washing Machines
I have a 8 track player-and forgot how to hook up to put it ,on a cd
What model, connected to WHAT?
OUTS go to INs, but don't conenct it to anything labeled "PHONO".
Mar 30, 2011 | NexxTech N2000
The numbers I have flashing on our top loader is #6 #7 #8
Hi just read your posting.Now from the information on your posting there are 8 lights in a row and starting from the left to right the lights that are lit are 6 , 7 , 8 ,is this correct?Please confirm your machines model number.If the information is correct then the fault on your machine is Display Module Fault.This means the computer has detected a fault with your Display Module.Please reply with additional information on the questions and I am sure I can help you further.
Aug 06, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water fill problem
raise hose from standpipe standpipe needs to be min 30-36 ins from floor drain line 6-8 ins into stand pipe also standpipe needs to be slightly bigger round than drain pipe to prevent siphoning
Jul 02, 2008 | Roper RAX7244KQ Top Load Washer
Dishwashers Logo
133 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
