My Maxwell ssb3wb lights are all flashing when I turn it on. Unable to press anything else because lights just keep flashing? What can it be? Can it be fixed?
1. Turn off printer 2. Hold down Resume
button and press Power button. 3. Keep holding down Power button and let
Resume button go. 4. Press Resume button 2 times then let BOTH buttons
go. 5. Green lights will flash and then stop blinking. 6. When green
lights are solid, press the Resume button 4 times. 7. Press the Power
button and the printer should turn off, if not, press the Power button
once more. 8. Your printer should respond as normal.For printer
This is all procedure, no need to disassemble printer.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal
1. Hold down RESUME and then hold down POWER 2. Release RESUME 3. Press RESUME twice, then release POWER 4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute: presses - light color - function
Number of presses - light color - function 0 presses - green - Test print (or exit service mode on i960) 1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850) 2 presses - green - EEPROM initialize 3 presses - orange - Reset waste ink counter
this may work for you 1. Turn off printer 2. Hold down Resume button and press Power button. 3. Keep holding down Power button and let Resume button go. 4. Press Resume button 2 times then let BOTH buttons go. 5. Green lights will flash and then stop blinking. 6. When green lights are solid, press the Resume button 4 times. 7. Press the Power button and the printer should turn off, if not, press the Power button once more. 8. Your printer should respond as normal..
