Coffee Makers & Espresso Machines Logo
V
Vision one Posted on Feb 25, 2018
There is steam/condensation behind by Gaggia Titanium espresso machine. How do I fix this?
1 Related Answer
EsWorld
Ernest R
  • 1618 Answers
  • Posted on Mar 05, 2010
SOURCE: Gaggia Titanium Espresso machine problem: steam
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Gaggia titanium
A nice coffee maker. So, please could you tell us what is your question?
Maybe some operating instruccions?
Check support library:
Or do you want to repair something?
Gaggia TITANIUM Espresso Machine Operating Instructions Manual
GAGGIA
Gaggia Titanium Super Automatic Espresso Machine
Cleaning Gaggia Titanium Espresso Machine Gaggia Titanium Steam Valve Replacement
My Titanium leaking water. Under it
The steam valve assembly that the steam knob on the right hand side connects into is probably faulty. When you're steaming if you hear hissing coming from behind the knob then this indicates the connections into this assembly are leaking steam, and also hot water, which is why you're getting puddles under the machine. You can get a replacement steam valve assembly that fixes some issues with the original (part code SVM-17, available from www.partsguru.com) and will prevent the leakage, or you could simply try opening the top of the coffee machine and removing the tube that runs from the boiler into the steam valve. It has two o-rings that provide the seal where it connects into the steam valve assembly, and if you lubricate these with a food grade silicon lubricant it may fix the problem. My Gaggia is 7 years old so I decided to replace the whole assembly which costs about $50 and that solved the problem completely.
Fix ventilate problem on gaggia coffee machine
Just try to pour some hot water out from the steam wand after some seconds the veltilate massage will go out.
Good luck
Gaggia Titanium that continues to Steam.
You need a new valve. Try getting the stainless steel valve assembly.
What does it mean when the Gaggia Titanium machine tells you to ventilate the hot water as soon as you turn the machine on?
Ventilate by pressing the hot water button and opening the steam tap. Once water flows freely, close the tap.
If problem persists, its likely to be a broken "steam valve cam"
No hot water or steam from wand.
If steam wand is not blocked then the problem is on the inside of the machine, try descaling the machine that might clear the blockage in the steam line.
2helpful
Gaggia titanium 120volts
open steam valve and run water couple minuts on
Gaggia Titanium, makes hot water but no steam
Push in on the steam knob, if that works, then the steam valve assembly needs to be replaced, tell the Tech where you bought the machine that you need to get the new stainless steel valve.
Top Gaggia Coffee Makers & Espresso Machines Experts
Sulejman Sulejmani
Sulejman Sulejmani
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
