I have changed toner sensor and developer yet no success.
SOURCE: sharp copier ar-5316
That unit uses an AR-016TD Toner/Developer Cartridge. The developer is changed each time you replace the toner. To remove the drum unit open the right side cover, then the front cover, remove the TD cartridge, loosen the green screw on the front of the developer unit housing just above the TD slot. carefully remove the DV unit without tipping or you will spill out the existing DV. Then you can pull out the drum unit. There may be a green screw on the drum that must be loosened but I don't think so on that particular model. Installation is the reverse of removal.
SOURCE: kyocera mita km-1530
press 1087 1087, then 131, press copy and then set toner level to 155. turn off machine and on again.
SOURCE: sharp ar5320 developer reset code
The developer doesn't have a reset code. It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days. You should order some developer.
SOURCE: PANASONIC DP8020E COPIER MACHINE PROBLEM
it means that the developing unit connector is not connected. you can find it near the location of the toner waste container. there will find one screw lock for the cover of developer harness. possibly one of the wires of the developing unit is open. you can solve it by just twisting or untwisting that wire; not need to replace just twist it or untwist it. :)
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
