Question about GE Kitchen Ranges
Oven wont work ge monogram electric oven 6 gas burners 2005 model mod.# ZDP36N6HSS
SOURCE:
  • 213 Answers
SOURCE: GE XL 44 GAS OVEN
there is an ignitor called a glow bar in the oven if its gone bad or just gotten weak the saftey valve wont open to let gas in so it wont be able to light. replaced the glow bar
Posted on Nov 26, 2007
  • 25 Answers
SOURCE: electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Posted on Feb 23, 2008
docjohn174
  • 943 Answers
SOURCE: GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Posted on Sep 30, 2008
WRMtech
  • 70 Answers
SOURCE: ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Posted on Feb 26, 2009
heatman101
  • 43501 Answers
SOURCE: I have a GE Monogram Gas Stove - 5 burner. All
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
w3
Posted on Sep 30, 2010
I am thinking about buying a used ge monogram range. Model number ZDP48L4GH3SS. I am trying to find the stats for it, but I am having no luck. Would especially like to know how old it is, what it weighs,...
All in the links below.
GE Appliances Model and Serial Number Locator
www.geappliances.com/ge/find-model-serial-number/
Find Your Model & Serial Numbers. Select your product type. Refrigerators & Freezers. Compact and Wine & Beverage Refrigerators · Bottom-Freezer Refrigerators · Chest Freezers · Icemakers · Side-by-Side Refrigerators · Top-Freezer Refrigerators · Upright Freezers. Cooking Products. Advantium Ovens · Cooktops ... Missing: zdp48l4gh3ss
How to Determine the Age or Manufacture Date of a GE Appliance
products.geappliances.com/appliance/gea-support-search-content?contentId=16195 How to Determine the Age or Manufacture Date of a GE Appliance. The manufacturing month and year is coded into the serial number (not the model number) of the appliance. Our serial numbers begin with two ... for further assistance. For information on old RCA appliances, see RCA Appliance Age or Manufacture Date. Missing: zdp48l4gh3ss
Discontinued Models - GE Appliances
www.geappliances.ca/en/products/discontinued-models Discontinued Models · Explore our GE Collections. Our Company. About us. Our Story · Appliance Donation Center · Press Room. Websites. GE Appliances Worldwide · Business to Business · Corporate Website · Careers · Monogram Design Centre ... Missing: zdp48l4gh3ss
Parts for GE ZDP48L4GH3SS Range - AppliancePartsPros.com
www.appliancepartspros.com > GE > Range Original, high quality parts for GE ZDP48L4GH3SS Range in stock and ready to ship today. 365 days to return any part.
Parts including Gas burners
http://www.appliancepartspros.com/parts-for-ge-zdp48l4gh3ss.html
These are posts about that Range
https://cse.google.com/cse?cx=partner-pub-9933858514302629:4836214790&q=ZDP48L4GH3SS&oq=ZDP48L4GH3SS&gs_l=partner-generic.3...146736.146736.0.147883.1.1.0.0.0.0.115.115.0j1.1.0.gsnos%2Cn%3D13...0.42j1764j2..1ac.1.25.partner-generic..1.0.0.BUEnm5lSMk4#gsc.tab=0&gsc.q=ZDP48L4GH3SS&gsc.page=1
Weight and Specs will be the same at 538 lbs.
ZDP48N6DWSS GE Monogram 48 Professional Range with 6 Burners and Griddle...
Jan 24, 2018 | GE Monogram ZDP48L4GHSS Dual Fuel...
Zgu36l6hss Hi. The simmer element on 2 of the burners are not working. Both of these are now hard to start with the electronic starters and on of these burners the spark stays on continuously. Any ideas?...
Check to see if you smell gas when you turn it on, make sure the igniter is clean all around it, make sure the caps are not on crooked. On the that wont stop clicking make sure the device that holds it to the main body is tight and has
always unplug electricity before attempting to repair on any electrical appliance good connection.
Sep 11, 2017 | GE Monogram ZGU36L6HSS / ZGU36N6HSS...
Gas in oven wont come on,burners and broiler ok, oven light comes on but oven won't come on,electrical connections ok, checked
this is a 2 burner oven with 2 ignitors . the bake ignitor is too weak to light the burner . replace it and the bake should work properly .. mm
Jul 13, 2010 | GE JGRP17 Gas Single Oven
heatman101
w3
Jun 15, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
GE Monogram Range igniters keep firing even when oven is off.
I had the same problem. Had GE out, they said it might be something but they'd have to take the cooktop off and it might be $300 or it might not. I unplugged it and now use matches.
Apr 21, 2010 | GE Monogram ZET3058SHSS Stainless Steel...
48" dual fuel burners clicking wont stop after lit.
just remove it from the board .
and please be carefull
.FRANKIE.
May 04, 2009 | GE Monogram ZDP48L4GHSS Dual Fuel...
Igniter issue for monogram gas cooktop
Be sure all caps are on correctly, then make sure the igniter is clean. Try using a tooth brush with soft scrub around the igniter, rinse, dry and try it
Sep 09, 2017 | GE Monogram ZEU36 Electric Cooktop
Kitchen Ranges Logo
35 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
