Question about Daltile Bathroom Accessories Resin Soap Dish Ceramic Tile & Stone
Listello resin 3 by 12 : tile;white grout stuck on the tile
The accent tile, by mohawk has many little holes in the pattern and a 3 dimensionalf lower and leaf pattern; should this be sealed with a natural stone or other sealer? how does one prevent grout from sticking; what about cleaning food splatters on tile from stove after installation?
    Problem Solver:
  • 11 Answers
Yes, you should seal all tile with a 3-5 year sealer. there are many brands to choose from. excess grout should be removed with a sponge and water before it dries. clean food splatters with any safe kitchen cleaner.
Posted on Jul 31, 2009
How to clean glass tile after installation
Follow the steps
1.Rub the grout haze with a dry cheesecloth. Shake out the cheesecloth as you work to remove grout dust.
2.Scrub the glass tile with a nylon bristle brush and warm water if cheesecloth doesn't work. Wipe away the loosened grout haze with a sponge as you work. Avoid using the nylon bristle brush in the grout lines of recent tile installations, as the stiff bristles may loosen or cause damage to the grout.
3.Mix a solution of 1 cup of white vinegar to 1 gallon warm water if haze remains on your tile. Scrub the grout haze with a nylon bristle brush dipped in the solution, wiping away the loosened grout haze as you work. Continued use of vinegar can weaken grout, so only use this method to remove haze and not for regular cleaning of glass tile surfaces.
4.Apply a commercial tile cleaner to the glass tile if the previous methods fail. Scrub the haze gently with a nylon scrubbing pad, letting the cleaner do most of the work. Rinse off the tile cleaner with clean water. Use a tile cleaner that is labeled for use on glass tile.
5.Remove the grout haze with a tile cleaner containing phosphoric acid or sulfamic acid as a final resort. These acids are safe to use on glass tile and are highly effective for removing grout haze. Avoid using phosphoric acid on colored grout, as the acid may cause bleaching or discoloration. Read the labels of these products carefully before using, and follow all manufacturer's safety precautions.
http://www.regalotiles.com/productinfo/details/terrazzo-terrasso-polishing/17
Oct 06, 2015 | Bellavita Tile Glass Tile - Bellavita...
Glass Shower Door
If you don't plan replacing the shower door, fill the holes with tile colour grout or other fillers you can buy from hardware stores. I am saying grout because if you have coloured tiles, the filled holes won't show prominently, otherwise fillers are ok.
Jul 10, 2013 | Home
How to Clean Tile Grout?
First mop the floors to get loose dirt up, use a stiff cleaning brush ( they make small versions of toilet bowl brushes. Toothbrushes are to flimsy.) I usually use tylex to clean grout it does have bleach in it. TO keep it clean after all that hard work put down a coat of grout sealant.
Jul 06, 2012 | Home
We are staying in a rented home with a spa bath. Attached to the spa bath is a hand held shower. The showerhead rests above the bath but the pipe coils somewhere between the tiles and the bath and can be...
The grout between tiles is just for filling the gaps. The tiles are glued to the wall, usually with "thin-set" mortar. Unless that mortar is in very poor condition it is unlikely that you would be able to remove that single tile without breaking it. The wall behind the tile might be water-resistant drywall (a poor quality situation) or it should be cement-board. I suppose it's possible that there is already a hole in the wall behind the tile, but the hole would be smaller than the tile, and assuming 4 inch (not large) tiles, this is a poor choice to gain access to the pipes. The usual access is through the wall from the other side. During initial construction, a removable access panel is sometimes provided (depending on local building codes and whims of the builder). If there is no access panel, and the other side of the wall is drywall, then cutting a generous hole, and fashioning a plywood panel (with trim around the edge to cover the gap between the drywall and the plywood) is a pretty standard and simple approach (depending on your skills). As an alternative and for more info, here's a link describing how to install a plastic snap-in access panel. Good luck! http://www.diylife.com/2008/06/23/plumbing-access-panel-installation/
Jun 01, 2011 | Home
How install the soap dish
There are a couple of designs, one is surface mount and the other is recessed. Surface mount mounts with silicone (hard to imagine it would last) and the other installed similar to a tile, but using grout. The grout install gets a hole cut in the tiles, goop everything up with grout, and goosh it into the wall, clean same as you would when working with grout.
Both designs need support until the adhesive dries.
Dec 12, 2010 | Daltile Bathroom Accessories Resin Soap...
Cutting resin tile
You need a tile saw that uses water to prevent sparking. Home Depot, Lowes..........<$100
Apr 24, 2009 | Daltile Bathroom Accessories Resin Soap...
Installing a resin shower soap dish,
liquid nails will do the job but you can also use clear silicone provided both surfaces are dry.
Feb 02, 2009 | Daltile Bathroom Accessories Resin Soap...
Daltile Bathroom Accessories Resin Soap Dish Ceramic Tile & Stone Logo
324 people viewed this question
Top Daltile Home Experts
Mike
Sal DeAngelo
woodzowl307
Are you a Daltile Home Expert? Answer questions, earn points and help others
