SOURCE: HI SERIAL NUMBER ON MY V-STAR 1100 , CAN YOU TELL
If you look at the VIN number on the headset of the frame, the 9th digit is usually the last number of the year
SOURCE: have a remington model 12 serial number #127375
Remington Year of Manufacture Codes maybe found on the barrel of your Remington rifle [or shotgun] on the left side, just forward of the receiver; the first letter of the Code is the month of manufacture, followed by one or two letters which are the year of manufacture. For shotguns with removeable barrels, the code will be valid for the manufacture of the barrel; maybe for the receiver, as barrels do get switched around.
According to the "Blue Book of Gun Values", the coding continues as follows:
Month Codes: [first letter]
B - L - A - C - K - P - O - W - D - E - R - X
1 - 2 - 3 - 4 - 5 - 6 - 7 - 8 - 9 - 10 - 11 - 12
Year:______Code: [second (and third*) letters]
1930_______ Y
1931_______ Z
1932_______ A
1933_______ B
1934_______ C
1935_______ D
1936_______ E
1937_______ F
1938_______ G
1939_______ H
1940_______ J
1941_______ K
1942_______ L
1943_______ MMZ
1944_______ NN
1945_______ PP
1946_______ RR
1947_______ SS
1948_______ TT
1949_______ UU
1950_______ WW
1951_______ XX
1952_______ YY
1953_______ ZZ
1954_______ A
1955_______ B
1956_______ C
1957_______ D
1958_______ E
1959_______ F
1960_______ G
1961_______ H
1962_______ J
1963_______ K
1964_______ L
1965_______ M
1966_______ N
1967_______ P
1968_______ R
1969_______ S
1970_______ T
1971_______ U
1972_______ W
1973_______ X
1974_______ Y
1975_______ Z
1976_______ I
1977_______ O
1978_______ Q
1979_______ V
1980_______ A
1981_______ B
1982_______ C
1983_______ D
1984_______ E
1985_______ F
1986_______ G
1987_______ H
1988_______ I
1989_______ J
1990_______ K
1991_______ L
1992_______ M
1993_______ N
1994_______ O
1995_______ P
1996_______ Q
1997_______ R
1998_______ S
1999_______ T
2000_______ U
2001_______ W
2002_______ X
* the years 1943 though 1953 had double letters: ie, MM = 1943
As maybe seen, the year code letters duplicate; some knowledge of when the model was introduced should resolve the actual year of manufacture.
Remington owners: COPY this table to your Hard Drive......! !
another couple helpfull links: http://www.remington.com/library/his...irearm_models/
http://www.hsph.harvard.edu/nviss/do...Codelist21.pdf
SOURCE: What year is my Remington 1100 Shot gun serial
here is a website where you can look for your shotgun and the pics of the different years that it's been made
http://www.remingtonsociety.com/rsa/journals/1100
SOURCE: i have a remington 22 cal model 12 serial number 187554 and would like to know the manufacture date
Introduction Year:1909
Year Discontinued:1936
Remingtons manufactured between 1921 and 1972 have a code located on the left side of the barrel near the frame that identifies the year and month of manufacture.
If yours is between 1921 and 1936, it should have two letters, one for month, and one for year.
If it doesn't have this code, it was made between 1909 and 1920.
REMINGTON Customer Service (1-800-243-9700 & follow the prompts) will look up your serial number and verify the age of your firearm.
Just to give some scope, serial number 757132 was 1929, about 569578 after yours.
