Question about Kole audio Q2-1440 Car Audio Amplifier
Know output from amp, power light is on. The amp has power it just stopped. kole audio class d qx3000 watt amp.
    Problem Solver:
  • 7 Answers
Check RCA cables..if not that, you may have lost a channel
Posted on Aug 01, 2009
My friend just got a KOLE AUDIO QX1-30000.. he's wantin to know if its a 3,000 watt amp or what because it says QX1-30000 on it??
This is the specs on it:
  • RMS Power Rating:
    • 4 ohms: 1100 watts x 1 chan.
    • 2 ohms: 1800 watts x 1 chan.
    • 1 ohm: 2300 watts x 1 chan.
  • Max power output: 3000 watts x 1 chan.
Jul 01, 2015 | Kole audio Car Audio & Video
Just wanted to know what the square boxes on top of my kole audio hk-980-2 amp was.
On the hk 980-2 those boxes are just for looks. I own one of these amps and im runnin 3x30amp fuses in it and it seems to put out 870-900 watts bridged at 14.5volts all day. I have an extra battery and i put 0-4 gauge reducers in mine. I have 2 memphis pr 12s and they sound really good on it.
Mar 08, 2012 | Kole audio HK980-2 Car Audio Amplifier
20,000 watts capacitor meter reading 13.9 with 2 battery & 250 alternator
Hello! The required voltage is 24 volts...which means two 12 volt batteries connected in series...It sounds as if you have two 12 volt batteries connected in parallel...Which doubles the amps and leaves the voltage at 12 volts...Connect the negative of one battery to the positive of the second battery...Then from the positive of battery #1 to the negative of battery #2 is the required 24 volts for the Kole...Guru...saailer
Jan 17, 2012 | Kole audio 20 Farad Digital Car Capacitor...
It worked for a week and now im getting no power to my subs
if it stopped suddenly i would check the fuses and work your way back to the where the remote start wire is attached. if you where pushing it hard the fuse is likely. also check the connections on the amp closely.
Jan 28, 2011 | Sony HK720-4 Kole Audio 4 Channel Car...
What sizes fuses go from battery to the amp on the kole audio 1920 watts kx2-1920?
depends on the size of your amplifier. what size is it? and how many channels? and what class?
Oct 22, 2009 | Kole audio KX2-1920 Car Audio Amplifier
Kole amp in protect mode?
Are you setting the bridge switch for both left and right or are you trying to run both subs off of one set of terminals? If you running the subs off one set of terminals you are effectively running the amp below 2ohms and thus the amp is not 2ohm stable and you will destroy it.
Some amps actually all ready run a bridged output for left/right operation, this could also be the reason why the protection circuit is kicking on.
Either way it's a component mismatch and you either need a stronger amp or different subwoofer setup.
Mar 09, 2009 | Kole audio Nitric XP2-2000 Car Amp
Kole audio q1-3000d
This amp is similar to many of the planet audio class D amplifiers. These amplifiers have quite a few problems. If the amplifier has failed, it needs to be serviced by someone who is familiar with the amplifier.
Do not repeatedly replace the fuses. It will lead to more damage and a more expensive repair.
Nov 12, 2007 | Kole audio Q1-3000D Car Audio Amplifier
Kole audio Q2-1440 Car Audio Amplifier Logo
117 people viewed this question
Top Kole audio Car Audio & Video Experts
Roadhog1169
Level 1 Expert
Terry Hair
Are you a Kole audio Car Audio and Video Expert? Answer questions, earn points and help others
