Question about Cycling
Hi. My name is mike. I have a 09 750 Brute Force. I recently added the k&n air filter and HMF exhaust. It rode fine the first week i was home. It set up for 2 weeks and when i come back i drove it and it has lost a significant amount of power. It seems as if it is not getting enough fuel or getting to much. I took the air filter off and it had motor oil under the screen. I also checked the belt and it was fine. Although the spark plug wire is a little cracked it. When i hit a mud hole with water it also seemed to die out even more. Do you have a solution? Really need help.
  • 313 Answers
Replace the plug lead and clean the spark plug you are getting a short at plug and this causes loss of power if there is oil on filter this is cutting amount of air getting through to carb as it blocks air flow..check to see if you have a gasket blown for the oil leak check near where the filter is .. if you run the bike for a while get a piece of clean white paper and hold or tape it in place near the engine then give it some revs and look for a spray pattern on the paper.. you may have to move it around a bit to find the leak.
Posted on Jul 31, 2009
My 06 Kawasaki 4 wheeler. Backfires when light switch is on going down highway. Is it battery related ?
Problem with Brute Force, please save my 4-wheeler from shop ...
www.kawieriders.com > ... > Kawasaki Brute Force/Prairie/Bayou
Nov 16, 2011 - Problem with Brute Force, please save my 4-wheeler from shop! ....2007 kawasaki 750 4 wheeler backfire problem ... should I save for my brute force 750? moe, Kawasaki Brute Force/Prairie/Bayou, 3, 10-18-2010 06:55 PM. Backfire thru exhaust
Feb 24, 2011
Low RPM Backfire Through Carb
May 24, 2010
four wheeler keeps backfiring
May 9, 2010
06 brute force 750 poping and backfire
Feb 18, 2010
More results from www.kawieriders.com
Oct 08, 2015 | kawasaki Motorcycles
05 kawasaki bf 750...battery was low......put a new one in..........now backfires out the exhaust.......tried the belt reset.....didnt help......suggestions.?.....
Brute force backfire problem - YouTube
? 1:06
www.youtube.com/watch?v=VFxGBYoVFqk
May 5, 2013 - Uploaded by gubba1957
I bought this 2006 750 it had a backfire problem when I bought it so I cleaned ... 2005 Kawasaki Brute Force 750 - Stock Exhaust Modification ...
Oct 03, 2015 | kawasaki 2005 Brute Force 750 4x4i
650 Brute overheating
change the air filter, an check the thermostat to make sure it opens
Aug 13, 2015 | Cars & Trucks
Belt light on Kawasaki Brute Force 750
Check YouTube.
There are a number of people that have made videos on how to resolve this issue. It involves making a small plug up and touching it across two terminals.
Jan 26, 2014 | Yamaha Kawasaki Genuine Kvf750 Brute Force...
Why does my brute force four wheeler barg down when I give it gas then it backfires
The float in the carburetor is possibly sticking. have the carb cleaned or run some carb cleaner through it.
Aug 27, 2013 | HMF Kawasaki Brute Force 750 08-11 Swamp...
Why ndoes my qaud loss power is it my plugs it started runnin week
as it is a quad I would check the air filter first for blockage next I would be checking the fuel filter for blockage and I would check the filler cap is venting properly.
Jun 11, 2013 | kawasaki 2005 Brute Force 650 4x4
Kawasaki 750 brute force brake
Remove and check the settings, check the bearings and the tolerance that is needed or if there was dirt or foreign particles that had caused this to happen. Also it can be due to worn out brakes.
Jul 04, 2012 | HMF Exhaust Kawasaki Bruteforce 750 05-10
Do you know what the carb settings would be for a 01 zx6r kawi with a hmf high mount exhaust
If only full exhaust system and air filter use 10 units larger MAIN jets and recheck the spark plugs for brown color.NOT white nor black.
The floaters should cut off the fuel just when they are parallel to the canister surface (if they are adjustable).
Don't change the idle jets.Use the stock.The needles stock setting as well.
Jun 04, 2009 | 2000 Yamaha YZF-R6
Cycling Logo
83 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
