Question about Philips 32PT6441/37 32" TV
Phillips model # 27PT644 1/37 this tv has
Phillips model # 27PT644 1/37 this tv has small colored horizontal lines on the top 3" of screen. is there any type adjustment that can remove them?
I'll sell you the solution for $75, you bunch of crooked A*#es
Posted on Jul 31, 2009
  • 27 Answers
You can adjust it into vertical section(variable resistor) but if cannot,..check the CAPACITOR near the vertical output I.C.
How do I fix a thin horizontal line near the top of my smart TV?
Live until more line appear as it will need a electronic board to be replaced.
Is the line black or colored ?
how thin and where on the screen?
https://www.youtube.com/watch?v=j7vl7-vZEL8
see attached video of another model for help. but the decision is yours
Mar 15, 2016 | Samsung 40" 1080p 60Hz LED-LCD Smart TV...
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
Horizontal lines on top of phillips tv
bad feedback electrolytic in vertical circuit. need tech.
Nov 23, 2008 | Philips TP2797B 27" TV
My Siny Trinitron G21M1 is producing horizontal lines across the screen
I hope your TV model is Sony KV-G21M1 and you see color bars as horizontal lines across the screen.
Let me now are you tech guy or know how to repair TV to guide you further.
Oct 26, 2008 | Sony Televison & Video
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Oct 08, 2007 | Philips 42PF9630A 42 in. Plasma Television
Emerson tv model no. ewf2704
Hi: When you say small horizontal screen, ¿Do you mean picture does not fill the screen completely from top to button? ¿Do images display normally though they are smaller in size? ¿Is color and definition of signal OK? Please answer so I can have a better picture of the problem.
Sep 19, 2007 | Emerson EWF2704 TV
Zenith Model SR3238RK horizontal lines
There must be a capacitor which would be brust or leaked.So check it in th horizental section.And power supply section.Find that one and replace it. Good luck
Aug 12, 2007 | Zenith C27A24T 27" TV
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Philips 32PT6441/37 32" TV Logo
510 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
