Philips TV Model 27PT5441/37 Serial #YA1A0428003608 July 2004 Chassis # L04.1UAA The TV will turn ON for a few seconds then shuts OFF. A green light on the front panel blinks a 1 - 2 - 3 code repeatedly. What is broken? How can it be fixed?
  • 27 Answers
Checked at the secondary voltage output supply, leaky components such as transistor, diode (zener)
Posted on Jul 31, 2009
I have a phillips 42fd9954 17s. when i turn it on the green light tuns on for like 6 seconds then fades . then nothing. no sound no picture. any idea. i am using a comp cord. had no cord when i got it
if you use vga input and there is no signal the tv shuts down in few second. It will wake up again if you provide vga signal or cycle it on off again. Change input to component or s-video and tv should stay on. On the other hand, this model has known problem with bad power supply unit but usually red light flashing when tv shuts down in that case.
Oct 16, 2011 | Philips 42FD9954 42 in. Plasma HDTV
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Philips 32PT6441\37 will not turn on. Flashing
You need the Horizontal Timing Kit for your TV. Chassis # is L04.1U AA can be found on the back of the TV. The part# is 4835 310 57673, Have a tv tech install this for you.!!!!
Oct 17, 2009 | Philips 32PT6441/37 32" TV
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
27'#27pts5441\37 serial#ya1a0505010585
Model # 27PT5441/37 needs Horiz Driver Kit ( L04.1U chassis)
Part # 483531057673 and replace 47mf/25v capacitor in horiz drive circuit....................................T.
Nov 22, 2007 | Philips Magnavox 27MS343S 27" TV
Hitachi Model 50UX57B
This problem was posted almost a year ago. Do you still need help or has it been fixed or replaced?
Nov 09, 2006 | Hitachi 50UX57B 50" Rear Projection...
Philips magnavox 25TS56
Same problem. The power button does not work. The volume and channel buttons turn the tv on. the tv then shuts its self off 15 seconds later. the red light blinks in second intervals while this happens.
Sep 16, 2006 | Philips Magnavox MS3252S 32" TV
Televison & Video Logo
153 people viewed this question
Top Televison & Video Experts
Electro Med Services...
