GOZ FROM INDIA
SOURCE: Password
Dell BIOS passwords can be reset by Dell Technical Support. There is no master jumper to reset.
1-800-624-9896
SOURCE: bios password
If removing the ROM battery (for a period of time, perhaps about 24 hours) does not help (and many people report it does not), you may need to take it to an official Toshiba distributor who will help you get past the password after you confirm that you are the legitimate owner of the notebook.
There is a reason for putting these controls on computers: it makes life difficult for laptop thieves, as it should. I only wish more manufacturers would do this. In the future, it would be nice if manufacturers allowed owners to verify their ownership (which they previously registered during machine initial system startup) online through a form, then download a file to a USB thumb drive that could be inserted during boot to allow the option of resetting (or unsetting) the BIOS password.
The following may not be very helpful:
http://www.uktsupport.co.uk/reference/biosp.htm
SOURCE: how to remove hasee laptop bios password
> You can try reseating RTC battery if that does not fix the issue
you may have to replace the system board, or check with the third party software providers whether they have any password breaker software.
SOURCE: how to remove cmos/bios password ?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Some BIOS manufacturer put a backdoor password
in BIOS which always works irrespective of what password you have set in BIOS.
Its a master password which is used for testing and troubleshooting purposes.your bios pass will depend on the motherboard manufacturer i.e(AMI,AWARD or PHOENIX)not by the laptop itself or the name of it..try these few pass listed below;
AMI
BIOS Passwords:
A.M.I.
AAAMMMIII
AMI?SWAMI
BIOS PHOENIX
BIOS Passwords: BIOS NOTE: All these passwords are case-sensitive and are
changed from time to time by manufacturers.
CONDO
HEWITT RAND
LKWPETER
MI
Oder
PASSWORD
AMI_SWAWARD
BIOS Passwords:
01322222
589589
589721
595595
598598
ALFAROME
ALLy
aLLy
aLLY
ALLY
aPAf
_award
award
AWARD_SW
AWARD?SW
AWARD SW
AWARD PW
AWKWARD
awkward
CMOS
phoenix
PHOENIX
Award BIOS backdoor passwords:
ALFAROME ALLy aLLy aLLY ALLY aPAf _award AWARD_SW AWARD?SW AWARD SW AWARD PW AWKWARD awkward BIOSTAR CONCAT CONDO Condo d8on djonet HLT J64 J256 J262 j332 j322 KDD Lkwpeter LKWPETER PINT pint SER SKY_FOX SYXZ syxz shift + syxz TTPTHA ZAAADA ZBAAACA ZJAAADC 01322222
589589 589721 595595 598598
AMI BIOS backdoor passwords:
AMI AAAMMMIII BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER A.M.I. CONDO
PHOENIX BIOS backdoor passwords:
phoenix, PHOENIX, CMOS, BIOS
MISC. COMMON PASSWORDS
ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj
OTHER BIOS PASSWORDS BY MANUFACTURER
Manufacturer Password
VOBIS & IBM merlin
Dell Dell
Biostar Biostar
Compaq Compaq
Enox xo11nE
Epox central
Freetech Posterie
IWill iwill
Jetway spooml
Packard Bell bell9
QDI QDI
Siemens SKY_FOX
TMC BIGO
Toshiba Toshiba
