Question about Samsung SCH-u340 Cellular Phone
New Phone Not Charging
I just bought this phone today and it was low on battery. I have been charging it for hours now. I turned it on and it says "low battery" then cuts off. Plus when it should be charging it doesnt say anything, its just a black screen, shouldnt it say "charging"?
My nokia N73 mobile phone getting low battery fast. after charging the battery the battery power remains only up to maximum of 2-3 hours. i brought a new original battery to check whether its a defect of...
This is a very common problem with the nokia N73 phone,
The problem you are experiencing with your phone is not from the battery but rather from the panel of your phone,
The panel of your phone is corrupted,hence its irrationally discharging the battery rather than storing up the charge.
The solution is to ;
1.take apart the phone,
2.Conduct a thorough cleaning and servicing of the phone panel.
3.If problem persists,it means the panel of your phone is gone and needs a replacement.
Best of luck!!
Aug 13, 2010 | Nokia N73 Cellular Phone
My phone only works when it's plugged into the charger
New batteries are shipped partially charged. Before you start using your device, it is recommended that you charge the battery. Some batteries perform best after several full charge/discharge cycles. You can charge the battery in two ways: • Charging the device’s battery by connecting the power adapter. • Connecting your device to a PC via the provided Mini USB cable. Note: Only the AC adapter and USB cable provided with your device should be used to charge the device. Charging is indicated by a solid amber light on the left LED indicator. As the battery is being charged while the device’s power is on, a charging icon will be shown on the title bar of the Today screen. After the battery has been fully charged, the left LED becomes green and a full battery icon appears on the Today screen’s title bar. Warning! Do not remove the battery from the device while you are charging it using the AC or car adapter. As a safety precaution, the battery stops charging when it overheats. When the low-battery warning appears, do the following: • Immediately save your current data. • Synchronize with your PC or connect the power adapter to charge the battery. • Turn off your device.
Hope this helps, let me know if I can help you with anything else.
JimmyC
Jul 14, 2009 | UTStarcom Blitz Cell Phone
Won't charge after the battery runs low.
that means your battery is flat so first boost the battery using universal charger or in other way charge you battery directly
Apr 08, 2017 | Sony Ericsson XPERIA X1 Smartphone
Phone won't hold charge at all
it's because of water damage, there should be a little square && it should be WHITE, most likely if your having this problem its because the little square is RED.
buy a new phone.
Apr 29, 2009 | Samsung SGH-a737 Cellular Phone
LG KG800 charging problem.
if you already change the battery;' theres no problem with the battery; i think the problem is software try to reset the factory setting if dosen't work/ reinstall software
Feb 04, 2008 | Cell Phones
Hi Robert, actually its LG and the batteries are the worst - i did the same thing with my brand new shine! You need to be careful when you start a new battery - make sure you drain it 100%, then charge for 6-8hrs, then drain 100% then recharge - after that you are good.
a new chocolate battery goes for $25-40
thanks
Jan 21, 2008 | LG KG800 Cellular Phone
Battery Charging
If both the charger and the battery are warm to the touch, the battery is probably charged.
The low battery level warning level is learned by the phone. To train it, allow the battery to run down once until the phone stops working, then recharge it.
The best way totest the charging operation would be to try using the phone. Fully charged you should get about 6 hours of talk time from a fully charged battery, and at least a week of standby operation.
Dec 25, 2007 | Motorola Mobility V176 Cellular Phone
Samsung SCH-u340 Cellular Phone Logo
82 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
