Question about Maytag Neptune MAH5500B Front Load Washer
No power; washer full of clothes; door locked.
No power to my Maytag Neptune front loader. Stopped either while washing or maybe it had just finished. Dryer is fine switched outlets but still now power to washer.
  • 98 Answers
Check your power cord...you may need to replace it...or just tighten the screws that hold it in place. It is very easy to do, if I can do, so can you!! You can order a part on line or from a local repair shop.
Posted on Jul 31, 2009
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
I have Maytag Neptune front loader washer. When
Hi.
Error LR means Locked Rotor.
Either the motor is faulty, there is a wiring problem, or the control assembly is faulty.
Try tripping the circuit breaker to reset the machine, if code comes back a technician must have a look at the motor.
Jun 13, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer
check to make sure the door is locking when it should. If the door isn't locking or sensing that its locked the washer will not go into high speed spin.
Mar 31, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Clothes still wet on Maytag Neptune Front load - only light load
any front loader should be operated with more than on piece of clothing in it. otherwise it is unable to balance the load.
Mar 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Won't drain all the way and door lock won't light up
Clean out the drain pump and check the pump motor while it is dis-assembled.
Mar 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Loader Washer
Sounds like the door lock unit isn't locking and may be bad. It is also a possiblity but not likely that there could be a problem with the computer board but start with the door lock unit first
Dec 29, 2008 | Maytag Neptune Washer
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front loader
I would say that you have damaged your door lock. Most appliances have a door lock or a mico switch. this is the first port of call for the power to supply the w/machine.Safety measures??? go back to basics,is the door locking, any power to the going to the electronics. a door. Change faulty components???
Aug 14, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
427 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
