Question about Dishwashers
No Water goes into Dishwasher - Dishwashers
  • 10,865 Answers
If there's no water entering your dishwasher, check these:
Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Posted on Jul 31, 2009
Dishwasher not allowing water in
Sounds like the "water inlet valve" is defective.
The valve is located in the bottom/back of the machine, is sometimes blue in color, and is at the end of the hose that attaches under the sink to the hot water.
The valve is smaller than your fist.
The valve has a couple of wires attached to it, and also has a smaller hose that goes up to the bottom of the dishwasher.
Be blessed.
Mar 25, 2013 | Maytag MDB5100 Dishwasher
Dishwasher heats up and goes through the cycle but no water.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 08, 2010 | Kenmore 24 in. 15932 Built-in Dishwasher
It is not getting any water,it runs just no water
Bad solenoid where water goes into the dishwasher. follow the tube from the water pipe in your house to where it goes into the dishwasher. turn off the power to the dishwasher. the small plastic pump(solenoid) where the tube from the house goes into the dishwasher is what you need to change. It has one electrical plug, two hoses attached, and a couple of screws holding it to the frame. remove the plug, the hoses, then the screws. Take bad solenoid and model number of dishwasher to hardware store they should be able to help you get the right one.
Sep 23, 2010 | Frigidaire Dishwashers
Help my dishwasher will not fill with water but goes through cycle
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 16, 2010 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher goes through the cycles but no water is circulating or coming in
heatman101
Aug 29, 2010 | Maytag Dishwashers
No water goes into dishwasher
Check the water inlet solenoid, it may be sticking/stuck Soak in a bit of WD40 or CRC. and, try a bit of percussive maintenance, IE: give it a "bit of a whack"
Feb 09, 2010 | GE Nautilus 24" Built-in Dishwasher
Water not going into dishwasher
make sure the water supply line is turned on and that it isn't kinked.
Sep 17, 2009 | Zanussi 24 in. DA6141 Built-in Dishwasher
Neff dishwasher not filling up with water
neff dishwasher will drain water goes in but the top and bottom spray do not work tablet falls in goes through cycle but will not wash. iangas
Feb 14, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Water leak
TIGHTENED NUT ON UNDERSIDE OF DISHWASHER WHERE THE HEATING ELEMENT GOES THROUGH.
Sep 12, 2008 | Frigidaire 24 in. FDB510LC Free-standing...
Dishwashers Logo
288 people viewed this question
Top Dishwashers Experts
Owen Barnes
