Question about Freezers
My Roper upright freezer is having temp control problems.
My Roper upright freezer is having problems. Some food stays rock solid and some food is soft. Ice cream, for instance, is always very soft. Also we lost a couple of items on the top shelf in the frost so we defrosted the unit, thinking that too much frost might have something to do with the problem. The frost is back on that top shelf and we still have the problem. I tried turning up the setting but this doesn't seem to help.
    Prodigy:
    An expert who has answered 500 questions.
  • 512 Answers
You have a loss of freon.
Posted on Oct 23, 2017
jumptrout51
  • 3361 Answers
SOURCE: top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Posted on Mar 12, 2009
tborn6
  • 700 Answers
SOURCE: upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Posted on Mar 28, 2009
jumptrout51
  • 3361 Answers
SOURCE: top rack frosting bottom of freezer won't freeze ice cream
Your door seals are leaking air.
Posted on Jul 17, 2009
nnesmith
  • 162 Answers
SOURCE: I have a Frigidaire ffu1466gw0 Upright Freezer.
if the compressor is running, the fan beside the compressor and the fan in the freezer should both be running, dirty coils can cause a problem. frost buildup on back of freezer wall is indicative of defrost problem.
Posted on Jul 26, 2009
SOURCE: I have a Frigidaire upright freezer model#
I have had the same problem with my frigidaire/electrolux upright freezer... I am researching to see if there is a pattern. Once or twice a year for the past few years, the freezer defrosted itself. I found the outside of the unit to be VERY hot to the touch around the time that this occurred.
We typically unplug it for a chunk of time when this happens and then replug it. It has always begun working again.
Sadly, we have lost many groceries and have had to clean many bloody meat messes as a result of this. ANYONE buying this freezer should save their receipt... That way, they can return it or have it repaired when it fails. I hate to think of sending all of these failing monstrosities to the landfill... =(
Posted on Aug 14, 2010
Top shel and top door shelfs are not freezing food solid ... Bottom freezes , all food on top portion thaws
you may have ab ad fan inside the cooler and all of the cold air is staying at the bottom. Also there may be bad insulation at the top and there may be warm air up there.
Jan 11, 2016 | Amana 20.1 cu. ft. Frost Free Upright...
I have already described the problem. the freezer temperature keeps going up and down the red light is flashing all the time. As we are not able to get an engineer until next Thursday almost 12 days since...
Set the temp control to max cold. Also, the thermocouple coud be touching something where it shouldn't.
Empty the freezer and reset. Also you may not know this but any lost food stuffs could be covered under the freezers warranty.
Jun 13, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My upright Frigidaire freezer is not freezing completly. The food is still frozen but when I put in my new popcilcles to freeze ( a week later) they are slushy when they should be completly frozen solid....
Check temp. in freezer shoud be 0 to -5 Deg. Check condensor if dirty clean some units had a recall on diers cap.tube to far in dier also check for ice on back wall if icedup check defrost heater and defrost timer check evap. fan make sure it's turning.
May 19, 2010 | Frigidaire 20 cu. ft. / 566 liter Upright...
New freezer not cooling - temp @ 25 degrees and food is defrosted
It is probably the control board and since it's new it's still under warranty so a certified Frigidaire repair man will fix it without charge. There should be a telephone number with the paperwork you received when you bought it.
Aug 29, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Old hotpoint upright freezer only has 1 temp artic blast....
I would replace the thermostat because is the only thing that controls the temp. , also there's a timer and a terminator but them are only for defrosting the unit.
Aug 13, 2009 | GE 16.7 cu. ft. / 473 liter Upright...
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer Not Freezing Food
there is a circulation fan and also a vent. Either the fan is blowing, or there is a cloged vent.
Feb 11, 2009 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer runs constantly
not necessarily, is it maintaining temp? all food staying frozen? especially ice creams if stored in there. most newer freezers displace the heat generated while cooling the food through copper lines running through sides of unit, helps to cut down on air temp differences between the inside (0 degrees) and outside temp to prevent moisture and possible condensation causing premature rusting of unit
Mar 02, 2008 | Kenmore 14.1 cu. ft. / 399 liter Upright...
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
Aug 13, 2007 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezers Logo
225 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
