Question about Sanyo M1 Cellular Phone
Plugged into power point using USB cord no go. Tried plugging into computer phone lit up then nothing.
MY alcatel FIERCE ONE TOUCH CELL PHONE WONT CHARGE UP LIGHT LIT BUT NO CHARGE AND WHEN I PLUG IT TO MY PC USB UNRECOGNIZED ?wHAT DO HAVE TOO DO SO THAT I CAN FIX THIS PROBLEM WITH MY alcatel FIERCE ON
Have you tried using another charging cord? There could be a fault there. If the cord is the only one you have, see if you can find a friend with the same phone to test whether theirs works for you, then buy a new cord if that's the problem.
Sep 21, 2014 | ALCATEL-LUCENT USA INC One Touch Fierce 4...
Connect usb port
Check all computer connections and cords. Is the powerstrip for surge protector light indicator bar (usually inside the off/on switch itself) on?
All it takes is a pet to walk over it or a foot to bump a cord and break the power connection. Mine do it all the time. Check the power on/off button on the printer to see if it accidently got powered down.
Sep 19, 2013 | HP Officejet Pro K5400 All-In-One InkJet...
How do you transfer pics from motorola v3m to computer using usb cord
Connect your phone to the computer using the usb cord . In my computer look for the removable disk not represent the motorola phone. Open the folder and access the pictures, press ctrl A to select all the pictures and right click the mouse, at the drop down command select send to and choose my documents then my pictures.
Nov 02, 2010 | Cell Phones
Computer runs off battery only not the power cord (battery is brand new)
You have a serious problem with the power and charging circuit. Normally if the battery is faulty the laptop can function with the power adapter plugged and running off the mains.
If a techo cannot fix without replacing the motherboard, then replacing the motherboard might not be a cost effective solution.
You salvage the hard drive by inserting it into an USB hard drive adapter case and use it as an external USB hard drive.
Sorry about this, you have very few options.
May 14, 2009 | Gateway MX6447 Notebook
Powersurge on USB ports
Have a close look at the USB ports, make sure you don't have any bent contacts touching the outer part of the connector and shorting.
May 04, 2009 | Dell Latitude D410 Notebook
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Phone cords
With the lines lit on the phone, it's indicating an off-hook condition or no battery from the line. Check the lines for dial tone at the demarc to determine if it's phone company problem. Thank you. Jer
Feb 18, 2008 | Panasonic KX-T7730 Corded Phone
Samsung mp3 player k3
This happened to my daughter's mp3 player, it wouldnt turn on even when plugged into the computer with the USB cord. On the back there is a reset, take a pin, press it in and reset the unit, I did it for about 2 seconds. Tried turning on the player and it turned on. Hope this helps.
Oct 16, 2007 | Samsung YP-K3 MP3 Player
Sanyo M1 Cellular Phone Logo
27 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
