Question about Precor Exercise & Fitness
I have a Precor EFX 556 elliptical cross fit trainer and the Quick start functions OK but i cannot get the programs to function?
  • Precor Master
  • 1,594 Answers
3 Suggested Answers
SOURCE:
dcramer531
  • 1654 Answers
SOURCE: How do I replace the
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots on whom the sell parts and support to.
There is a place on line to get some of these, it is. www.treadmilldoctor.com/Products-Services2/precor-treadmill-belt.
The manual can be found at. fitness.manualsonline.com/ex/thread/view/idThread/2141832
This place has manuals and user manulas along with support and some partswww.shopwiki.com/Precor+EFX+5.171 I believe this unit has a 10 yr warranty with it and the part in question may be covered by them. There is also a 1 year part warrant for other parts, I just don't know what parts they are covering for the 10 yr.
Posted on Dec 26, 2010
info95456
  • 10 Answers
SOURCE: My Precor EFX 5.17i elliptical trainer keeps displaying "Error 40" even when I turn it off and back on. How can I fix it?
This is an incline error. Check fuses and incline gear for jammed incline. Call 877-805-1030 or www.techmotionusa.com for service tech if you still need help
Posted on May 09, 2015
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
Precor EFX 5.23 Crossramp controls don't work
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH This could be a simple solution. It may be that the overlay/keypad is no longer functioning properly.
Repair Parts for Precor 5 23 Ellipticals Consumer SPORTSMITH net
Please have your serial number available.
Oct 12, 2014 | Exercise & Fitness
Loud groan from rear of machine
Typically this is caused by a bad pillow block bearing. I would suggest trying to pin point the sound a bit better, but this is common of the pillow block bearings.
Precor Parts for EFX 554i 556 556i Ellipticals SPORTSMITH net
Dec 23, 2013 | Precor Exercise & Fitness
Precor efx 556
Here you will find parts and other information for the Precor EFX 556.
Repair Parts for Precor EFX 556 Ellipticals SPORTSMITH net
Jan 07, 2012 | Precor EFX 546i Elliptical Version 4
Dead battery on Precor EFX 546i Elliptical - options on how to handle, please? Thanks very much.
This link will allow you to use your model and serial number to find the correct battery along with the service manual with replacement instructions.
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Feb 13, 2011 | Precor EFX 546i Elliptical Version 4
My 546i is telling me to pedal fast after I hit Quick Start or manually start a program. It's obviously not working. I just put a new battery in it too.
This problem maybe coming for n the generator it performs 3 function 1. controls electrical load / resistance to pedals 2. Charging system for the battery 3. Monitors unit when in use (stride) or when it is idle.
To test unit: Remove cover disconnect red battery lead. then use a multi-meter set function to ohms set range that can read 50 ohms. then disconnect generator lead from circuit board. M3=brown , M4= blue, M5= violet, with the meter read between Brown and blue, blue and violet , brown and violet, each of these read should be between 26 and 27 ohms. If any of the reading s are high or low replace generator
Jan 24, 2010 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
69 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Ross Metcalfe
Ross Metcalfe
Jose Pino
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
