Pull start works
SOURCE: tractor wont drive or engage electric clutch.
It thinks you aren't sitting on the seat.
There are 2 wires and a switch under the seat. The plug may have come off, the connections might be bad, or the switch might be bad.
SOURCE: Toro Lawn Mower Electric Start Won't Engage
you'll need to pull the starter. It sound like your Bendick's is bad. that's the upper gear drive assay. the only other res ion would be, low power to the starter, and not receiving an acquit amount of amp to reach the rpm's it needs. good luck
Testimonial: "Thank you for the advice.... I will check out the Bendix to see if that is the problem. Jim"
SOURCE: The recoil starter on my Briggs & Stratton not engaging flywheel
Andy, Hi, well I would start at the Starter myself, usually the thing called the "Bendix" spring jams up and stops it dead. Pull of the Starter, and power it up, off the unit. This will show you if it snaps in and out.
Sometimes a few judicious whacks with a soft hammer will sometimes free up the spring, if thats is indeed what's wrong. Anyway try that first. before any disassembly.
Make sure the Motor CAN actually be turned, by turning the flywheel, this should show you if the Motor is "Free" enough to move.
Also check ALL electrical connection to the starter. Use a meter and see if you are actually getting a voltage to the starter too. make sure your starter battery is good too.
Below is your support site, for any manuals or parts required.
http://www.briggsandstratton.com/maint_repair/
SOURCE: Starter spins but will not engage flywheel...
I JUST GOT TWO NEW STARTERS AND I HAD TO PUT A FEW DROPS OF OIL ON THE STARTER WHERE IT ENGAGES, THAT FIX MY PROBLEM.
