Question about Coleman Pressure Washer PW0881800
I have a Coleman 2750 power washer that just idels when you pull the handle. Why is it not reving up with pressure?
    Brigadier General:
  • 4,090 Answers
Possibly has leaking seals or there is a blockage in the gun or hose. remove the hose first and see if it is putting out enough water.
Posted on Jul 31, 2009
Coleman Powermate pressure washer. Model PW0751310 A lot of water leaks out in the handle where you squeeze for the unit to work, thus the power spray is weak at best. Took handle/arm apart and didn't...
There may be orings in gun but usually not available as a repair kit. Replace the gun with a 5000 to 6000 psi. You will get a much longer life by over sizing gun. If you like to tinker, you can by orings at Lowes in the plumbing department. Lube the orings with silicone paste (also sold at lowes). Good luck
Mar 17, 2011 | Caterpillar Cat Pump Pressure Washer Pump...
Coleman Pressure Washer gets no pressure even when running.
It sounds like your pressure regulator or back flow preventer is stuck closed either by corrosion or trash . Try tapping it and see it will open. If this does not work you can try rebuilding or replacing it.
Nov 18, 2009 | Coleman Powermate Powermate 5000W...
I have the Coleman powermate 2400 PSI pressure washer and on initial start it sprays and has great pressure. But once I release the spray handle it will not spray again, not even one drop of water. I have...
Sounds like the valve in the handle is sticking closed. May have a broken spring, or maybe a part is stuck..
I say take it apart, and the answer will present itself.. Play with it with nozzle out too... Maybe something is stuck after storing so long and will loosen up.. Fingers crossed
Oct 22, 2009 | Coleman Garden
Just fired up my Coleman Powerwasher 1100. I have
Nozzle is plugged. Stick small diameter wire in nozzle.
Aug 30, 2009 | Coleman Garden
Describe your Honda Maxus Prosumer 2750 PSI Pressure Washer w/ GX & CAT Pump - MX5223 Problem keeps dying
if it has a bowl on the bottom of the carb you float might be stuck, and check if the air cleaner is dirty
Jul 02, 2009 | Honda Maxus Prosumer MX5223 Pressure...
WATER LEAKS FROM INSIDE THE 1400 PRESSURE WASHER
Replacing Compasster, where on the terminal block does the black and white wires go?
Mar 08, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Coleman Pressure Washer PW0881800 Logo
267 people viewed this question
Top Coleman Garden Experts
John Trevino
Simon Flummox
Simon Flummox
Are you a Coleman Garden Expert? Answer questions, earn points and help others
