SOURCE: I have an Edge 491 Exercise bike and the control
Take a look at the battery compartment under the panel (left looking up). I had a similar problem and had just fixed it. Hopefully you can get the same results.
If the strip of metal with the spring is corroded, take the batteries out, and carefully remove the metal strip. I used metal duct tape and wrapped the piece of metal with the tape. Carefully put a slight bend in the middle of the strip and reinsert the strip. If the batteries do not connect up, bend the piece a bit more or add more of the metal duct tape. After doing this, the panel came back to life. If this is not your problem, then my apologies. If it is, then good luck.
SOURCE: battery missing for exercise bike
I have a Schwinn airdyne (model AD-3) that uses a button type battery in the count-down timer, which is above the work load indicator or the 'speedometer'. According to the manual I was given with the bike, it utilizes a 1 1/2 volt watch - type battery (LR44, A 76 or equivalent).
Hope this helps.
SOURCE: edge 491 exercise bike monitor panel dead
http://www.academy.com/images/pdf/Fitness_Quest/Edge_Recumbent_Bike_491r.pdf
Mine went dead last Spring. I ordered a replacement part from Fitness Quest. I think the link is above. Actually, while I was waiting for the part, I reconnected all the wires on the whole bike and the panel worked. So I actually have an extra new working panel if Fitness Quest doesn't have the part for some reason and u want mine. Double check ALL the connections of the wires first. They come loose easily.
Nancy
SOURCE: Need Manual for Vital Fitness Exercise Bike RB26S
I have a manual for this model. I can not tell you how to find one, I have looked all over the net for additional info. on this model and can't find anything. Would be glad to scan and send you a copy if you still need it.
SOURCE: Olympus Sport Exercise Bike part number 280E037 R ...
UK Suppliers details:
RFE International
The Performance Centre
Maidstone Road
Kingston
Milton Keynes
MK10 0BD, UK
+44 (0) 1908 793020
[email protected]
