SOURCE: radio won't pick up any stations on samsung u600
make surre that you have your handfree pluged into your phone as this acts like an antena. then go options and self tuning, that will then search for radio stations and you will get a list of them. all you have to do when you get a list if radio stations is click on one.
SOURCE: Do you repair radios? 65 Nustang AM. I can only
Go to carsandparts.com.It's an old car magazine's web site. They have an extensive classified ad section broken down by maker and model. These ads include companies that repair and replace almost anything, including radios. Hope this helps.
Testimonial: "Very informative"
SOURCE: 99 Sunfire: Radio not picking up stations out of
the easy way is remove the radio from the dash leave plugged in remove the anttenna wire from the radio stick a small screwdriver in the anttenna socket and see if the recpetion is better you may have to hold the screwdriver with your hand to be a better antenna if so thier is something wrong with your antenna coax or antenna if not doesnt help then the radio is bad internally
SOURCE: my concert radio wont pick up AM stations
your probably in a bad place and you wont pick up a signal like if your out of cell phone range, except your probably out of radio range for am stations.
SOURCE: How do I stop my MG100HDFX from picking up radio stations........I CANT PLAY LIKE THAT!!!!!
Have you changed out your guitar cable? Also, if you have a broadcast antenna close to your practice area, that could be your problem. Try moving your amp to another location and see what happens. If it picks up stations at different locations that are miles apart, call Marshall...the amp is defective.
