Question about Magic Chef MCBR440 Compact Refrigerator
Compressor cycles in and out every two or three minutes
  • Magic Chef Master
  • 4,654 Answers
Replace the thermostat. Sea Breeze
Posted on Aug 27, 2009
I have a new Delonghi portable AC PAC N115EC (11,500BTU), is it normal for the compressor in this particular A/C to be cycling on/off every 2 to 3 minutes?
If the room is cool, it sounds like the unit is operating correctly. It could be short cycling because the unit is over sized for the room being conditioned. if you can, increase to size of the load by opening a door into another room. As long as the refrigerant pressures equalize from high to low side internally and the compressor doesn't start up under load, you should be fine
Sep 10, 2016 | DeLonghi Heating & Cooling
My manitowoc series 420 has a code telling me the compressor discharge temperature
Which code is that? I don't see that in the service manual. There is an E09 that indicates that during the first six minutes of freeze the discharge temperature was below the average of the last 6 cycles. I have searched from E01 to E31 and don't see the code you indicate but I would say you either have a low refrigerant charge, a flooding TXV that is allowing too much refrigerant flow into the evaporator and not allowing enough flow to be diverted into harvest, or a weak compressor. Reset the unit and check the temperatures on the display while its running and time a freeze cycle. Should take about 15 minutes to make ice.
Jun 28, 2013 | Manitowoc ID-0452A 420 Lb Full Size Cube...
LRA2575T2 compressor runs for about out three minutes then cuts off after about three more minutes i can cycle the fan econ cool switch it will cool for three more minute any ideas
Possible blockage causing compressor to shut off, or compressor on it's way out. Check the fan is running full speed when the compressor starts
Aug 07, 2012 | Frigidaire Heating & Cooling
Haier Mini spilt HSU18VC7 compressor runs for 5 minutes then stop 3 minutes then run another 5 minutes and so on.
This is called short cycling. It sounds like the compressor is getting hot and opening a bi-metal overload, which shuts the compressor off. The compressor cools, because it is not running and the bi-metal contacts close allowing the compressor to start again. This will repeat itself and is usually due to low refrigerant, which usually means there is a leak in the normally sealed refrigerant lines. The refrigerant cools the compressor windings and if it is low it cannot do that, hence the shutting off of teh compressor, cooling down process and restarting of your compressor. Short cycling will ultimately ruin the compressor.
If this has helped you please give me a rating worthy of my diagnosis.
Aug 03, 2011 | Haier Heating & Cooling
Magic Chef MCBR1000w stopped cooling
If the compressor runs on 120 volts AC, (some are three phase DC, you can use a 3n1 hard start kit, they are very simple to use and cost around $20 dollars, you can purchase them at HVAC supply stores. If the compressor continues to short cycle after installing the hard start kit, then you need the compressor replaced and should check your warranty, this is often an expensive repair.
Jun 15, 2009 | Magic Chef CTB1821AR Top Freezer...
Compressor cycling on and off
Check the relay on the compressor. Also check the capacitor. It iwll be one of two prob lems most likely the relay
Jun 02, 2009 | Heating & Cooling
Is it normal that new A/C compressor continousely works
It is not normal. Consider seeing another auto technician before the car ac gets another thing bad in your lovely vehicle.
Cheers.
rate this.
May 25, 2009 | 1996 Mercury Grand Marquis
Coleman mach 8333 kicks breaker
I changed out the startup and run capacitors. A/C runs fine now
Jul 22, 2008 | Coleman Mach 15 Air Conditioner
Unit Cools for two minutes and takes a three minute break.
There is a safety shutting down the compressor. Either the thermal overload is cutting it off because its getting too hot for some reason. Dirty coil, filter or fan speed, though you said the fan is running so that's out. Does the compressor feel really hot when its cycling on and off? If its not, its possible the thermal disc is bad, but unlikely. The other safety is low pressure (freon) You kind of need a set of A/C gauges to test this accurately. Hope this helps. These safeties are there to prevent the compressor from burning out, when something small is the problem, as its the most expensive part. You sound like have covered all the bases, so check the coils and filter, if there still is a problem, then you need to call a service tech. for warranty.
Mar 07, 2008 | Amcor PLM-14000E Portable Air Conditioner
Magic Chef MCBR440 Compact Refrigerator Logo
133 people viewed this question
Top Magic Chef Refrigerators Experts
John Tripp
John Tripp
Lawrence Oravetz
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
