Question about Lux PRODUCTS EP100 COLOR CHANGING EGG TIMER
The timer turned purple. what does that mean?
  • 10,515 Answers
Usually Purple indicates a Soft Boiled Egg.
Thanks.
Posted on Jul 31, 2009
Tablet wont turn on
Blue means that your system is not charging, when it is charging it should be pink/purple. when the battery is full it will turn blue. If the blue/pink light stay on it may mean that your battery is no longer charging completely. If it is still under warranty, get a replacement battery for free... otherwise it may be time to invest in a new battery.
Jan 16, 2014 | Computers & Internet
Maytag gas dryer model SDG4606AWW timer wont rotate on any cycle, dryer just keeps running until knob is rotated manualy to off, replaced timer and new one is doing the same, took dryer compltley apart,...
I don't have a Maytag schematic handy but there should be one on or in the dryer. Trace the clock wiring back until until you get voltage. I am betting one leg of the time motor goes to the drum motor (Gray wire maybe) and the other leg to the dryness sensor module (brown wire). Check these wires against both Line and Neutral. That should tell of it's the module or the motor block.
Nov 04, 2013 | Maytag Dryers
Troubleshooting m460g timer
you should have power across the two wires to the timer while it is running . Power needs to be on the timer for it to work. One wire should be low ohms to the ground or metal surface and the other wire should be the power wire to the timer motor. if no power on the other wire to timer follow it back and you may find an open in a door switch or temp switch. good luck
Nov 04, 2013 | Maytag Dishwashers
My blackberry wouldn't turn on I put it in the charge but the red light wouldn't come and it wouldn't turn on
Try to turn it on again if it doesn't take it apart and you will see a purple paper. If the paper is not purple then it means it got wet and you need to take the phone where you bought it from and tell them the insurance covers it and you will get a new blackberry.
Nov 06, 2012 | Cell Phones
I need the color meaning of each wire so I can install the kdc138
red - 12v battery
yellow- 12 ignition
black- ground
blue/white- amp turn on
white FL+
white/black FL -
gray FR +
gray/black FR -
green RL +
green/black RL -
purple RR +
purple/black RR -
Feb 16, 2011 | Kenwood KDC-138 FM / AM Receiver
Replaced lamp in projection tv PT52LCX65-K1.Now have a green and purple image 3 -4 inches slightly to left of screen,also a purple one to right of centre,they appear intermittantly.Also the change lamp,and...
First- Did you replace just the lamp itself. If you did, you must make sure the lamp is flush into the lamp cage.
Second - Make sure the new one (if you bought it complete with cage) is flush also.
If you didn't have this problem before and have it now then retrace your steps.
Dec 20, 2010 | Panasonic Televison & Video
Samsung DLP HL-R5667W not turning on. Showed
Purple spots means Bad Light Engine Part number is BP96-00822J Encompass Parts Has them for
$950.00 - $350.00 core price Part $600.00
1-800-638-3328 Lamp# BP96-01073A
Ballast Board# BP47-00027A
Jan 08, 2010 | Samsung HL-R5667W 56" HDTV
Dryer just stopped working
che the thermal fuse on the blower housing should be 2 purple wires going to it also change the thermostat beside it if its open cct
Jun 29, 2009 | Dryers
Motorola H700C - purple light
its on paring mode that means that its ready to be pared up with the phone.i would just close it to turn it off and reopen it and connect
Jul 17, 2008 | Motorola Mobility H700 Wireless Headset
Lux  PRODUCTS  EP100 COLOR CHANGING EGG TIMER Logo
66 people viewed this question
Top Lux Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Lux Hardware and Accessory Expert? Answer questions, earn points and help others
