Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
I HAVE A 1998 CHEVY K2500 7.4L V8 SFI. THE TROUBLE IS WHEN I AM DRIVING THE MOTOR TRUNS OFF LIKE LOSS OF POWER. OR SOMETHING. SO I STOP THE TRUCK AND TRY TO RESTAR IT BUT NO LUCK. THEN I GET OUT AND GO UNDER THE HOOD SHAKE THE WIERS TO THE FUSE BOX 2X3 TIMES AND THEN IT STARS AND GOS FOR 1 OR 2 HRS. CAN YOU TELL ME WHAT TO DO. THANKS MATT
  • 162 Answers
Disconnect the battery and remove the fusebox then check the wire connections under it as well as the wire connections of the wires going to it
Posted on Jul 31, 2009
  • 69 Answers
Sounds like you have a bad ground wire. make sure all your wires are tight and not corroded.
Wondering how much power
Gas Mileage16 mpg City/24 mpg Hwy
EngineGas V8, 6.2L
EPA ClassCompact
Style NameCoupe 2SS
DrivetrainRear Wheel Drive
Passenger Capacity4
Passenger Doors2
Body Style2dr Car
TransmissionEngine, 6.2L V8 SFI (426 hp [317.6 kW] @ 5900 rpm, 420 lb-ft of torque [567.0 N-m] @ 4600 rpm) (Requires (MN6) 6-speed manual transmission.)
Apr 16, 2014 | 1998 Chevrolet Camaro
1998 chevy blazer. Do I drive it in 2wd, 4wd hi or low what is the difference and can it do damage?
always drive in 2wd only use 4wd when traction could be a problem and 4wheel low when stuck or off road use
May 25, 2012 | 1998 Chevrolet Blazer
How can you tell what type of transmission is in my 1998 chevy malibu
Whether your Malibu is:
(a) 4 cylinder 2.4L SFI DOHC Vin "T", or
(b) 6 cylinder 3.1L SFI OHV Vin "M"
SFI = fuel injected
DOHC = dual overhead camshaft
OHV = overhead valves
Vin = 17-digit unique car identifier - the 8th digit identifies the engine (not the transmission), and
as you can see, your engine will be identified by the 8th digit = "T" or "M"
your car has the Chevrolet 4T40E automatic transmission (aka "automatic transaxle")
Here are some specifications:
Feb 18, 2011 | Chevrolet Malibu Cars & Trucks
Need a list of everthing it would take to install a 5.7 v8 in a 1998 s10 that cane with a 4 banger
Look on the internet for "Chevy S-10 V8 conversion". There are companies that offer a kit with motor mounts, harnesses. ECM, differential and/or gears, transmission, etc. If you want a more precision engine to convert to, I suggest the 5.3L. That is a mean motor that will give you decent gas mileage and more power than a 350. Trust me, if you have to save a little longer to afford the 5.3L it is well worth it. Please rate me on this answer.
Jun 14, 2010 | 1998 Chevrolet S-10 Pickup
1998 chevy vortec v8 stops accelerating at 3000 rpm when engine at operating temp. problem is worse in warm weather. it will accelerate below 1/4 throttle then when you get in the throttle it just stops....
Have you checked all your vacuum lines. One may have rotted and has a hole sucking in more air then needed messing up the air fuel mixture. Take a can of carburetor cleaner and while the engine is running spray short bursts around the carb and theintake manifold and where any little black hose lines are hooked up.If the engine revs up in rpms then it has an intake leak sucking in air where its not supose too.
This will cause power loss. Also check your air filter to make sure it is not plugged up. Ihope this helps, The Raz
Apr 15, 2010 | 1998 Chevrolet K1500
1999 chevy suburban 2wd 1500 v8 driving
I suspect you have had an oil pump failure. To get at the rotory gear oil pump you will have to drop the oil pan. After you take the pan off, ( having drained the oil the oil pump is what the oil pick up line leads into. That pick up assy. is a round shaped disc with a screen inside it. Clean the screen first then the oil pump. Install new oil pan gasket on reassembly. Hope that helps you. Please let me know.
Hopefully the engine was not damaged when the pump broke. If it was you may need a complete engine rebuild, MAYBE.
Jan 26, 2010 | 2003 Chevrolet Suburban 1500
1999 Chevy C3500 with a 5.7L SFI wont start
a crank position sensor could be bad or your cam position sensor could be bad
Jun 06, 2009 | 1998 Chevrolet C3500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
471 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
